Showroom ODrive Turnigy 190kv BLDC 6DOF - Here we go again
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Oct 12, 2019.
  1. BlazinH
    16,691Coins
    The good is that you can still have VR like in games released before VR since most of the popular ones have 3d Vision support. And with TrackIR you can add head movement too. There's also not the issue of needing motion compensation. :)
    The bad is Nvidia discontinued 3d Vision support in their drivers soon after VR became viable. Also I thought old used stock of 3d Vision equipment would be cheaper now but the opposite is true and prices are higher on used equipment than is was new in most cases. :(
  2. SilentChill
    20,601Coins
    Oooo goodies
  3. SilentChill
    20,601Coins
    Oh shit, think I went overboard with the 27's lol 22 or 24 would of been fine
    • Like Like x 5
  4. pmvcda
    15,702Coins
    :eek: Do you think the central post can handle it?
    I have to say, that using the monitor close, is not VR, but easy to get immersed.
    And I'm having fun with BeamNG. There's no VR. I'm trying to trash the rig with collisions! Frighting to go head to head with a truck! Just imagine it in VR.
  5. SilentChill
    20,601Coins
    No Iwill need end supports but I knew that before I bought it i just couldnt be arsed making my own and for £40 it was just easier.
    And i want the screens for GTA and FS2020 because it wont have VR at launch as much as we wish it
  6. SeatTime
    May do something similar, as my capsule came originally with screens, so all the mounting points are still there. Weight/inertia is now not a issue as it does not move :). Could also be good for adding motion to 4K videos - roller coasters etc.
  7. SilentChill
    20,601Coins
    Added a couple of supports and the triples are totally solid ow, no flex at all
  8. JAD
    JAD Active Member
    Australia
    1,446Coins
    Are those 27in monitors 1440P?
    Im looking forward to see how these run with your 2080ti.
    Now you got me thinking of going triple also.
  9. MagicMunkyNuts
    MagicMunkyNuts Nothing ventured, nothing gained.
    Disability Support.
    Maffra, Victoria, Australia.
    271Coins
    @SilentChill I downloaded a few plastic end caps through Fusion 360 when I was designing an 8020 chassis. They convert to .stl for 3D printing and it could end up saving you a bit of cash if you're considering adding them to your rig at any point.
  10. SilentChill
    20,601Coins
    No they are just standard 60hz 1080p. I'm not too bothered about the fancy screens as I will still do most of my gaming through VR.
    That's great if ya can share the file :) I didnt think of 3d printing them I need a shit load of them
  11. MagicMunkyNuts
    Disability Support.
    271Coins
    @SilentChill
    Yeah no worries, just grab a few measurements of the internal and external dimensions of the square tube you've used and I'll do some online hunting for the right bits, convert them to .stl and send them your way in the Discord chat.
  12. BlazinH
    16,691Coins
    The reason I started using 3d Vision years ago was for FSX. I was blown away with how much more immersive it was just like those that are using HMD's for the first time that have never experienced 3d before are. Considering FS2020 is being built from the old FSX code it would be awesome if we could invoke 3d vision with a renaming hack or something but probably wishful thinking.
  13. SilentChill
    20,601Coins
    I'm not sure there will e enough people who would want it now VR is here but you never know
  14. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hello AMC1280 work with bldc motor? thanks
    you i cant used on you project thanos AMC1280 ? or amc not work with bldc motor? thanks
  15. BlazinH
    16,691Coins
    Since you stated it won't have VR support initially though it would be fantastic if those of us that already have 3d Vision could just rename it and get it to work until it does (if ever) ;). I'd rather have a large screen with 3d Vision and TrackIR over triple flats myself.
  16. SilentChill
    20,601Coins
    I don't know you would have to ask Thanos best asking in his Discord channel habits veryvactive there
  17. Zed
    USA
    5,845Coins
    It's really easy. Make sure your meter is configured for voltage and one lead on one ground connection and the other on the ground you want to compare to. You’ll get a positive or negative voltage if there’s a difference.
    Also handy for checking household appliances for ground fault issues.
  18. Thanos
    Electronics Engineer
    2,908Coins
    Short Answer is no.
  19. SilentChill
    20,601Coins
    Slowly getting there have a few more teething problems to sort but I'm nearly there
    • Like Like x 8
    • Winner Winner x 3
  20. oppie
    oppie New Member
    Mech. Engineer
    the Netherlands
    81Coins
    Hi Silentchill,
    I've been following your (and FlyPT, Wickie's and Stijn's) work for quite some time now and I am really impressed by your results.
    Just want to let you know that your dedication to the simulator and this thread is highly appreciated and is inspiring me to start a similar project.
    Keep it up!
    Regards, Oppie
