4 DOF (PITCH-ROLL-TRACTION LOSS-SURGE)
Discussion in 'DIY Motion Simulator Projects' started by Enrico, Mar 11, 2018.
  1. Enrico
    Enrico Member
    417Coins
    4DOF
    ... then, before to post the settings a couple upgrade about the modify of the rig.
    This was the connection with the potentiometers:
    but didn't work well because to much slip between the wheels .
    This is the new solution
    This was the old rig
    This is the new one
  2. Enrico
    Enrico Member
    417Coins
    4DOF
    Now the settings
  3. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi to everybody I have a problem.
    My sim use for the movements 1 arduino uno and sabertooh 2x 32 (surge and TL ) and 2 JRK 12v12 to move the seat on universal joint.
    Everything was fine and funny :grin.
    Yeserday, for my fault I have fried a JRK.
    Because I had another Arduino uno and another Sabertooth 2x32 I installed them instead the 2 JRK
    No problems moving both motors with SMC3 Utils V1.01 but when I test the movments via SIMTOOLS OUTPUT TESTING one of the motors answer with a big delay (this do not happen with SMC Utils motion)
    Have someone some suggestion?
    SIMTOOLS is version 2.4
    ARDUINO has SMC3 packet serial beta 8 soft start installed
    SIMTOOLS is:
    bit per second 500000
    data bit 8
    parity None
    stop bit
    Intrface output 10ms (axis assignment is ok)
    I checked Sabertooth baud rate and is 115200
    Of course when run the game (PC cars 2) the movements are completly ...awfull
    I also changed language in windows 10 with english USA also if probably didn't need.
    Something else to check ?
    Thanks a lot
    152,283Coins
    +11,068 / 56 / -2
    Could you please post pictures of all of your settings.
  5. Enrico
    Enrico Member
    417Coins
    4DOF
    Here some pictures ...
    IMG_20200119_140240_BEAUTY.jpg IMG_20200119_140311_BEAUTY.jpg IMG_20200119_140432_BEAUTY.jpg IMG_20200119_140508_BEAUTY.jpg IMG_20200119_140658_BEAUTY.jpg IMG_20200119_140717_BEAUTY.jpg IMG_20200119_141332_BEAUTY.jpg IMG_20200119_141347_BEAUTY.jpg
  6. Enrico
    Enrico Member
    417Coins
    4DOF
  7. Enrico
    Enrico Member
    417Coins
    4DOF
    sorry, this is the correct URL
  8. Enrico
    Enrico Member
    417Coins
    4DOF
    ...nobody has some suggestion ?:think
    152,283Coins
    +11,068 / 56 / -2
  10. Enrico
    Enrico Member
    417Coins
    4DOF
    A rapid upgrade.
    The problem seems to be solved changing the value of Fpid in Smc3 from 1 to 2. I will test better next days
  11. BlazinH
    16,667Coins
    Glad to hear that may have fixed it. I answered your PM but didn't see your post above until now.
  12. Enrico
    Enrico Member
    417Coins
    4DOF
    Yes I saw your PM BlazinH and answer too there.
    Thanks again
