Hall effect potentiometer diy
Discussion in '3D Printing' started by MarcoMade, Mar 14, 2019.
  1. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
  2. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
  3. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
    Hi!
    Thank you. I was wonder if it possible to use this kind of system in my own project and now i have good position to start!
  4. MarcoMade
    italy
    157Coins
    sure, you can adapt to any gear motor system
  5. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    hi, does this solution provide the absolute position of the motor? also, it seems like you have to attach a magnet to the motor - is this correct?
  6. MarcoMade
    italy
    157Coins
    hello NO to the motor no magnet must be inserted. there are only two magnets surrounding the Hall sensor. it then returns a voltage value in relation to the position of the measured magnetic field.
    it does not reach the 5vdc output due to losses in the semiconductors, but it is sufficient to then calibrate the movement system in its 180 * of rotation.
  7. MarcoMade
    italy
    157Coins
    besides I add that my design, has the possibility to be adjusted in the desired position through the rotation of the cube that contains the two magnets and then fix them with two screws in the desired position. a kind of fine tuning of the position of the rig
    in edit:
    I add some photos just taken. after more than a year that is not even looked at by how well it works.
    as you can see from the photos, you have to build the adapters to connect the potentiometer to your motor, and my motors are out of the standard used by almost everyone. so for the support you have to arrange to build it yourself.
    I hope I made you light.
    live in peace,
    Marco
  8. MarcoMade
    italy
    157Coins
    IMG_20200126_100302.png IMG_20200126_100343.png IMG_20200126_100356.png IMG_20200126_100413.png the HAll sensor is then inserted into the hole until it reaches the magnets, you can help build the support with a breadboard and screw on the bearing base
  9. MarcoMade
    italy
    157Coins
    IMG_20200126_102338.png IMG_20200126_102344.png IMG_20200126_102355.png IMG_20200126_102404.png Hall sensors are A1302
    ahha :)
    I forgot .. the third dof. built 6 months ago ..
    I used a common wiper motor to pull the belts.
    here you can see better how to install from the attached photos.
    Hello
  10. Qlittles
    226Coins
    Sounds good! Thank you for the response and the photos - I think I understand now how to use your 3d print design.
  11. tadek
    tadek Active Member
    616Coins
    hi
    Do we gain anything from the operation of the engines?
    I would like to use a hall potentiometer for wiper motors.
    Will it mute some vibrations?
    greetings
    Tadek
    151,991Coins
    +11,061 / 56 / -2
    Hall sensors have good accuracy, long life and won't break if over rotated.
    I am not sure what you mean by "mute some vibrations", Hall sensors will be very responsive to movement input.
  13. MarcoMade
    italy
    157Coins
    I add to the already exhaustive comment of @noorbeast.
    If the motors vibrate, it is definitely not due to the Hall sensor.
    rather you have to use a shielded cable for the connections from the potentiometer to the board, a stereo shielded cable is sufficient where the braid will be the negative (ground).
    the wiper motors are very dirty about EMF. therefore the Hall signal cable can be influenced by continuous spikes due to the very stressed motor.
    in my case I have very powerful motors and they work without warming up very relaxed, but I used shielded cable, this is the solution.
    many greetings and let us know if you solve with this small upgrade hello
  14. tadek
    tadek Active Member
    616Coins
    Hello
    I have a question
    Do I need to change the smc3 code to use pot hall?
    Tadek
  15. MarcoMade
    italy
    157Coins
    no, then you only have to calibrate the limits and other parameters to your needs based on the power weight of the mobile station
  16. tadek
    tadek Active Member
    616Coins
    thanks
    that is, I connect the sensor as a regular potentiometer and calibrates the settings first in SMC3
    later in ST or FLYPT?
    best regards
  17. MarcoMade
    italy
    157Coins
    Yes, right. obviously respect the polarities of the sensor
  18. tadek
    tadek Active Member
    616Coins
    HI Marco
    What size of magnets did you use?
    best regaeds
  19. MarcoMade
    italy
    157Coins
    ciao
    8 diameter x 5mm height
  20. papito
    papito 2DOF + Traction Loss
    IT Manager
    Argentina
    26Coins
    2DOF, 3DOF, Arduino
    HI Marco!!!
    you did a really nice job !!! congrats !
    Im testing my DIY Hall effect pot on my traction loss Motor and is working good but with a narrow angle.
    I used to work with +/- 45 degrees and now is in +/-10 degrees...
    do I have to "touch" something?
    thanks buddy
    david
