Yaw vr
Discussion in 'Commercial Simulators and Peripherie' started by HASAN1453, Jan 30, 2020.
  1. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    Anyone using yaw vr? What’s your axis assignments, min/max for racing games?
    153,728Coins
  3. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    Ahh cool. I’m not alone. I’ll move to one of them
    153,728Coins
    What information has YawVR provided to you in terms of setup, as you are not the only YawVR owner looking for help?
  5. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    Nothing other than user manual which has this info(attached) for no limit roller coaster
    153,728Coins
    So with the proper IP and the Interface Settings configured as per that picture does SimTools Output Testing work if you configure the Default Profile in Axis Assignments as per the NL2 example given in the picture?
  7. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    40Coins
    Just need to set simtools axis limiting. Start off with 8% or less. Disable yaw at first and add try to add it later after you get pitch and roll working like you want.
