Showroom Efficient quiet compact 3DOF heave axis motion platform
Discussion in 'DIY Motion Simulator Projects' started by fzxj520, Jan 29, 2020.
  1. fzxj520
    fzxj520 Active Member
    1,341Coins
    Use laser cutting stainless steel to assemble a small amount of welding
    150W*3=450W
    Weight 75kg
    Load test
    Noise test
  2. fzxj520
    1,341Coins
    More pictures later
  3. Philip K
    Philip K New Member
    167Coins
    That is impressive! Looking forward to seeing more
  4. Gadget999
    12,035Coins
    i like the idea - can you fit more springs for more lift ?
    this concept will work on a 6dof also ;)
    the only problem you need to consider is if something goes wrong and the motor tries to rotate 360 degrees
  5. PairRoc
    PairRoc New Member
    China
    190Coins
    2DOF, SCN5, SimforceGT
    Nice setup with that 3 dof :D
  6. fzxj520
    1,341Coins
    Reasonable use of spring can reduce motor load and improve commutation speed
    In fact, many motion simulator designers have added springs to their designs
  7. RacingMat
    21,047Coins
    nice assembly!
    how does it work in the rig? how the seat is guided?
  8. fzxj520
    1,341Coins
    Some photos
    Evolve Motorsport
    Custom G Development
  9. fzxj520
    1,341Coins
    Yes, it can work on 6 DOF ===》Evolve Motorsport
  10. fzxj520
    1,341Coins
    I don't know what you mean. I don't know if this picture can answer your question
  11. fzxj520
    1,341Coins
  12. RacingMat
    21,047Coins
    Ok thanks
    - white U arm is going roughly up and down
    - Spring is here to compensate part of gravitation force during the lifting.
    But how the seat is guided up and down?
  13. Philip K
    Philip K New Member
    167Coins
    so if you were using this principle on a 6 dof, what spring rate would you use? If the rig is say 180kg inc person and peripherals, would you use 6 x 30kg rated springs?
  14. pmvcda
    15,394Coins
    Where is the spring in the Evolve?
  15. SeatTime
    Maybe he thought the dust bellows were a spring?
  16. MarkusB
    4,215Coins
    The spring rate is not defined in terms of weight, but as force per length (e. g. N/mm).
    For calculating the desired spring rate, you need to know your overall weight plus the maximum travel distance of your motors or actuators.
    You probably want the fully loaded rig to remain in neutral position with idle motors. And you want the springs to support the motors along the entire travel distance, or at least a large part of it. These could be the parameters on which you can base your calculation.
