Question Need help for C# progarm
Discussion in 'Miscellaneous' started by jakkrich, Feb 3, 2020.
  1. jakkrich
    jakkrich New Member
    Bangkok Thailand
    57Coins
    I have project to program 6 DOF from China in C# program. I have experienced with Arduino and serial connection for Simtools's link but this new project I have to develop in C# program because I have to send Axis's data to Vegafu Controller and I have Vegafu Controller's protocol and example in C#. So I want to use Memory Map File in C#
    https://www.xsimulator.net/community/attachments/mmf_starter-zip.38136/
    My requirement is exactly like this.(this example from yobuddy )Axis 1-6 positioning data. But I need to convert to C# programming . Could anyone help me to convert it or explain this program work. I very newbie for C# programming.
  2. Thanos
    Electronics Engineer
    2,854Coins
    Ahh, good luck with that... no-one was able to use that code they give for the vegafu is garbage.
    I'd suggest looking into bypassing the vegafu and interfacing the Dorna servos directly on a real motion controller for servos like the AMC-AASD15A.
    It supports the Dorna servos with custom wiring and a few parameters in the Dorna servos panel:
    Thanos
  3. pmvcda
    15,384Coins
    Can you share the Vegafu Controller's protocol?
  4. jakkrich
    jakkrich New Member
    Bangkok Thailand
    57Coins
    Thxs Thanos, I study your project in YouTube. Your controller might be my last option if I can't do it. I will replace Vegafu controller but I need to try first.
    Please see attached text file
    If you can explain me I really appreciate that.
    Btw. anyone can explain me about MMF please
  5. Thanos
    2,854Coins
    Like I said, that is not the actual code but instruction to use the actual code in your application... is that all they sent?
    Thanos
  6. jakkrich
    jakkrich New Member
    Bangkok Thailand
    57Coins
    Other file about UDP Protocol
    Could explain me about simtool's MMF?
  7. gzresident
    gzresident New Member
    China
    - 38Coins
    I am in China,and got some vegafu or mbox controller before,this kind controller mostly for VR sim platform.
    if you have motion position map file,just convert the data to G-code, but firstly flash GRBL code to stm32 or Uno r3,then just send g-code to serial port and control your 6axis platform.
