Senior Capstone Project - VR Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by Garrick H. Woods, Jan 8, 2020.
  1. Garrick H. Woods
    Garrick H. Woods Simulator Noob
    194Coins
    Thanks! yeah I'm fully expecting to have to change my configuration depending on how everything goes in testing. I have the fans set up so that one pulls air into the box, and the other pulls it out, creating a consistent air current. I might need to add some type of heat sink or another internal fan directly on the motor controller though.
  2. Garrick H. Woods
    194Coins
    I was trying to figure out a way to connect my potentiometers, since I don't have any more thread left at the ends of my motor shafts. I looked at possibilities of using couplers or tubing with cable clamps, but none of those options seemed good for my setup. I modeled some proportional gears and a mounting bracket to fit to my motor with pre-tapped holes in order to track shaft position using the potentiometers. Pictures below
    • Creative Creative x 2
  3. Garrick H. Woods
    194Coins
    I was able to get both of my motors to work with the SMC3Utils software (https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/) but when I try to test the motors from the SimTools Game Engine, I can't get them to work. I need to work on it some more. I've tried messing with different com ports but changing the port for the Arduino hasn't worked yet. It's probably something simple but I'm not sure what to try next. If anyone else knows how to fix this let me know!
    153,830Coins
    +11,151 / 57 / -2
  5. Garrick H. Woods
    194Coins
    I made sure that the com port is correct and the settings are the same as in the tutorial but I can't get it to do anything in sim tools. The SMC utility works fine.
    I also tried removing the "a" at the end of each axis with no luck. What other settings should I post?
    153,830Coins
    +11,151 / 57 / -2
    Have you created a Default profile in Axis Assignment, as that is what is used in Output Testing to check SimTools, prior to trying it out with games. We really need to see pictures of all of your settings.
  7. Garrick H. Woods
    194Coins
    153,830Coins
    +11,151 / 57 / -2
    You can grab the SimTools manual from here: https://www.xsimulator.net/community/threads/official-simtools-user-manual.12424/
    At this early stage why are you using Axis Limiting? I would suggest that only if using something that can break, like an SCN.
    If you are only using 2 motors then your Interface Settings should be like this: [A<Axis1a>][B<Axis2a>]
    You do not need Axis Assignments for b, as you are only using a.
    The pink indicator top right of Game Engine indicates that Game Manager is not connected, was it running at the time?
    You don't need it just yet but I would suggest you swap the Axis Type to 2D Generic Advanced, as once you get the basics sorted you may want to have the filters exposed for fine tuning.
    I just want to confirm that you are not running SMC3 and SimTools at the same time, as that will cause a port conflict, and that the Arduino is on Comm Port 4 in Windows Device Manager.
  9. Garrick H. Woods
    194Coins
    I've checked this as well. Yes I have the SMC3 off when trying to use SimTools, but for some reason it's not working
    153,830Coins
    +11,151 / 57 / -2
    The Arduino being connected is not an issue, it is the SMC3 utility used to configure SMC3 that will cause a port conflict if running at the same time as SimTools.
  11. Garrick H. Woods
    194Coins
    I realize that haha. I was responding to the second part of your question on that line. I have made sure that the SMC3 is not running at the same same because I know that it can create a conflict
  12. Garrick H. Woods
    194Coins
    It might be a sign of an issue that my output testing doesn't count down when I press turn on like every video I've seen.
  13. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    Do you mean that Output Testing does not work?
  14. Garrick H. Woods
    194Coins
    No. I can't get simtools to move my motors at all, but smc3 works perfect
  15. MarkusB
    4,215Coins
    No, this is not a sign of an issue. It's a sign that you are using the latest version of SimTools.
    See the SimTools v2.4 Release Notes, which say:
    SimTools v2.4 Updates and Changes
    - Output Testing has been revamped. (Gone is the 3..2..1.. countdown).
  16. Garrick H. Woods
    194Coins
    at least I'm doing something right haha
    153,830Coins
    +11,151 / 57 / -2
    If Output Testing does not work try temporarily disabling anti-virus and firewall then test it again.
  18. Garrick H. Woods
    194Coins
    I've tried disabling the firewall and antivirus and still no luck. I have searched around and it seems like other people have similar problems to my own, but never post if they resolved it or how they did so. I feel like I'm beating my head against a wall a little bit.
    I just don't understand how SMC3 could work so perfectly and I get no response whatsoever with sim tools. I feel like I've tried every way in the program to change settings with no luck.
    153,830Coins
    +11,151 / 57 / -2
    Just to confirm, you have corrected Axis Limiting?
    If SMC3 works as expected temporarily disable anti-virus and firewall and reinstall SimTools, check configuration and Default Profile, then try Output Testing.
    Perhaps @yobuddy has some further ideas.
  20. Garrick H. Woods
    194Coins
    Yes, I removed the axis limiting. I also tried uninstalling simtools and re-downloading it, but it didn't seem to change anything.
    Is there anything I possibly forgot to configure when setting up simtools? I've read the manual 2 or 3 times to try to find what I'm missing but I haven't been able to find anything.
