Question One of your interfaces requires GamerEngine to be restarted
Discussion in 'SimTools Pro & Entertainment Version' started by Cramer, Jan 12, 2018.
  1. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    Hi!
    I have the same problem. I'm also setting up SCN5 interface with two axis and I get the message "One of your interfaces requires GameEngine to be restarted".
    I already checked ID things and it's set up correctly. In fact when I start Game Engine one of the axis goes to middle postion but only one of two. If I disconnect working one COM6 port then not working COM8 axis starts working. So they work separatly but not together.
  2. yobuddy
    51,529Coins
    Are they both on the same power supply?
    Maybe its going out?
  3. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    Yes, they are connected to the same power supply. But it's a mean well 24v 4a power supply. And I'm able to connect to second SCN5 via Dyadic software
  4. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    Just figured out that I'm not able to connect to them simultaneously using two Termi-BUS apps.
    Probably they somehow interference with each other. Maybe my auto directon control was somehow messed up. [​IMG]
  5. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    I got them working together. Please watch the video.
    But when I go to SimTools only one of them working. Second COM port is disconnected and I'm able to connect to him via Termi-BUS.
  6. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    Sorry for many posts.
    But I got both working by SimTools 1 time in 10.
    Sometimes works only first actuator, sometimes only second and rarely working both. :confused:
  7. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    Ok! I found a problem! It was actually error in auto direction control schematics.
    Now everything is working.
  8. stefan1958
    stefan1958 New Member Gold Contributor
    Cologne
    230Coins
    3DOF, SCN6
    I have the same or simllar problem as Rasul reported. when I start the game engine , then only one of my 2 dof prosimu snc6 works at a time. both are working but not together. once the left and once the right actuator is working. I had this issue already sometimes in the past but now I have to restart 30 times or so. actually I don' t get both working together at all. everything in my setting is the same as before. and very rarely it works fine... frustrating! I have used different USB ports and a powered hub... but it doesn' t matter. Rasul said "it was actually in auto direction controlls scematics" sorry for the stupid question but what does this mean... is it something in the game engine settings?
  9. Shane Rthrfrd
    Shane Rthrfrd New Member Gold Contributor
    Toronto, Canada
    57Coins
    Were you able to correct restat game engine issue with your SCN 5? If so,please share diagnosis?
