Question No Surge motion
Discussion in 'Project Cars' started by DarkHunter82, Feb 22, 2020.
  1. DarkHunter82
    DarkHunter82 New Member
    96Coins
    Hello, I have builded a 3dof simulator. The third motor is for yaw or traction loss...
    All works, but the surge power don't move motor, but in test level there are the telemetry parameters.
    In another game, dirt 2, surge works well.
    There is a problem with pc2 plugin?
    152,283Coins
    +11,068 / 56 / -2
  3. DarkHunter82
    96Coins
    Sorry for the late answer... Is possible to elimate all parameters and plugin and reinstall all?
    In this way, I hope to reset.
    152,283Coins
    +11,068 / 56 / -2
  5. DarkHunter82
    96Coins
    Thanks for the answer... I have tried but nothing news: I don't have surge motion... What is the best plugin for Project Cars 2? And how I can have the surge force?
    152,283Coins
    +11,068 / 56 / -2
    Please post pictures of all of your settings, including Axis Assignments and Tuning Center.
  7. DarkHunter82
    96Coins
    This is my settings
    152,283Coins
    +11,068 / 56 / -2
    Your Tuning Center values are way too large for surge, and I would suggest sway also. In some games I even have surge values less than 1.
    Follow the tips here, especially capturing Max/Min values in the Tuning Center as a base, then initially tweaking each axis individually: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  9. DarkHunter82
    96Coins
    Thank you noorbeast. Sorry for the late answer. I have tried but now i have a very very low motion on surge. i have to put the gain high to have a motion.....low....but motion.
    152,283Coins
    +11,068 / 56 / -2
    Did you capture the Min/Max in the TC?
    What TC value do you now have for surge, as it was originally way too high? Try 0.5, that should liven it up, then tweak from there.
