iRacing when starting practice or race session crashes Simtools Game Manager
Discussion in 'iRacing' started by tdg911, Feb 7, 2019.
  1. tdg911
    tdg911 New Member
    IT Consultant / Developer
    Louisiana
    121Coins
    Hello all,
    This is actually my first post. I've been browsing through the forums here for a few weeks trying to learn some things here and there. I recently purchased a DOF Reality P3 system and just got everything setup last week. This week I'm working on trying to tweak the movements. I'm new to the sim world but have a very strong technical background and my troubleshooting skills are pretty good as well.
    I have learned quite a bit from you all and appreciate all of the support here in the forums.
    Here's my scenario. I'm running the latest version of Simtools on a Win10 Pro system (recently installed fresh), plenty enough ram and very minimal system configuration. I'm also running the latest Nvidia drivers for a 1080ti GPU and latest drivers and software for Oculus Rift. I wish I were home so I could post my version numbers but everything is the latest.
    I just setup my iRacing account and began messing around with that and everything has been going ok with two exceptions.
    1) When starting a practice session and/or race session, sometimes the Simtools Game manager crashes with an unhandled exception error. I have the option to continue or quit. I will then start the game manager while iRacing is still loading and will get a second crash. It seems after iRacing finishes loading I can start the game manager again and motion works just fine. This isn't every time. Just some times.
    2) I am not able to get surge working in iRacing but it works in AC. I can post my settings later but hopefully someone can help me out.
    Has anyone experienced the first issue when starting a session from the browser?
    TIA!!
  2. nclabs
    196Coins
    First of all I always launch both Simtools apps before launching iRacing but I never had this kind of crash issue. I would check your .net framework with the repair tool from MS, for a start. The surge issue it's a lot stranger. Did you already tried to uninstall simtool and start back all over? I got a crashing issue time ago and it was just the simtool's installation gone wrong.
    152,977Coins
    +11,116 / 56 / -2
    If you have a crash error then please post a picture of the full crash report, as that will tell us what is going on.
    I don't use iRacing but suspect them most likely issue with surge is your settings. DOF reality has a thread for support questions: https://www.xsimulator.net/community/threads/low-cost-2dof-3dof-motion-simulator-dof-reality.8570/
    Which includes a link to another link where DOFreality owners can share setting: https://www.xsimulator.net/community/threads/dof-reality-platforms-presets-profiles-and-tips.11273/
    You will find DOFreality iRacing settings posted there: https://www.xsimulator.net/communit...-presets-profiles-and-tips.11273/#post-152578
    Just be aware the Axis Allocations for this and many other DOFreality posted setting have Axis Assignments of many hundreds of % in total, which will result in clipping: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    The proper way to refine a profile is one axis at a time, with an Axis Allocation around or slightly over 100% in total: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  4. FredBasset
    FredBasset Member Gold Contributor
    461Coins
    I get this too, doesn't happen every time but probably 1 in 5 starts. I'll post up an image of the error next time I see it
  5. nclabs
    196Coins
    I correct myself, yesterday I had the same exact issue. I need to learn how to shut my mouth. >_>
  6. FredBasset
    461Coins
    That will learn you as they say in my home town!
  7. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    iracing.PNG Resurrecting this old post to see if there has been any solution to this issue. I still have this problem even with the latest version of simtools. Game manager will crash about 80% of the time when I launch iRacing. Is the only solution to this is to launch iRacing before the game manager is launched? I have also tried to reinstall the .Net framework but that did not resolve the issue.
    152,977Coins
    +11,116 / 56 / -2
    Please copy and paste the full error message.
  9. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    System.IO.FileNotFoundException: Unable to find the specified file.
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.MemoryMappedFiles.MemoryMappedFile.OpenCore(String mapName, HandleInheritability inheritability, Int32 desiredAccessRights, Boolean createOrOpen)
    at System.IO.MemoryMappedFiles.MemoryMappedFile.OpenExisting(String mapName, MemoryMappedFileRights desiredAccessRights, HandleInheritability inheritability)
    at iRacing_GamePlugin.GamePlugin.GameStart()
    at SimTools_GameManager.Mod_Lib.GameStarted()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.4.0
    Win32 Version: 0.2.4.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    EwaRlRjyQRIFJmdLrQQpzimRMOv
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AssettoCorsaCompetizione_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/AssettoCorsaCompetizione_GamePlugin.dll
    AssettoCorsa_GamePlugin
    Assembly Version: 2.0.7.0
    Win32 Version: 2.0.7.0
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/AssettoCorsa_GamePlugin.dll
    DCS_GamePlugin
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/DCS_GamePlugin.dll
    DirtRally2_GamePlugin
    Assembly Version: 2.0.1.0
    Win32 Version: 2.0.1.0
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/DirtRally2_GamePlugin.dll
    DirtRally_GamePlugin
    Assembly Version: 2.0.0.3
    Win32 Version: 2.0.0.3
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/DirtRally_GamePlugin.dll
    EliteDangerous64_GamePlugin
    Assembly Version: 2.0.0.2
    Win32 Version: 2.0.0.2
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/EliteDangerous64_GamePlugin.dll
    iRacing_GamePlugin
    Assembly Version: 2.0.3.2
    Win32 Version: 2.0.3.2
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/iRacing_GamePlugin.dll
    KartKraft_GamePlugin
    Assembly Version: 1.0.0.1
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/KartKraft_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    NoLimits2_GamePlugin
    Assembly Version: 2.0.1.17
    Win32 Version: 2.0.1.17
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/NoLimits2_GamePlugin.dll
    pCARS2_GamePlugin
    Assembly Version: 2.0.5.4
    Win32 Version: 2.0.5.4
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/pCARS2_GamePlugin.dll
    VideoRidePlayer_GamePlugin
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/VideoRidePlayer_GamePlugin.dll
    XPlane_GamePlugin
    Assembly Version: 2.0.2.0
    Win32 Version: 2.0.2.0
    CodeBase: file:///C:/Users/micha/AppData/Local/SimTools/GamePlugins/XPlane_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  10. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Does anyone have any insight into this error message?
    152,977Coins
    +11,116 / 56 / -2
    It looks to me to be triggered by a file not found issue, have you tried re-installation?
  12. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks for the reply Noorbeast,
    This issue is intermittent and only affects iRacing. It’s been happening on more than one PC and with older versions of Simtools as well. And based on the other posts in this thread, others have also reported this issue. I have also reinstalled .Net.
    When it happens, if I restart Game manager after iRacing has loaded, it works fine. It only crashes once.
  13. noorbeast
    152,977Coins
    +11,116 / 56 / -2
    Perhaps @yobuddy can have a look, when he has time.
  14. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks.
    I hope @yobuddy has some time to look at this soon as it's a real annoyance :).
    Thanks always for the support.
  15. Chrhun
    Chrhun New Member Gold Contributor
    - 57Coins
    My first message, but not last for sure! I'm having the same issue. When I first start Iracing, I get that Net Framework error. However, if I then close IRacing and restart, then it works despite how many times I leave the game and start it again.
  16. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    @value1 or @yobuddy
    Could this possibly be a timing issue with the iRacing plugin and it creating the memory mapped file on startup? Can one of you take a look at this issue? It seems to be affecting a lot of people that use iRacing.
