FlyPT Mover 3.5.3
  1. pmvcda
    15,458Coins
    Working on the basic pose from motion...
    Not organised!
    So like I said before, red dot is the output value after temporal filters like low pass, high pass...
    Gray dot is the value without those filters.
    There's no way to show a line with those filters, because the result depends on how fat we change values.
    But this gives already a good help, I hope :think
  2. hannibal
    hannibal Active Member
    4,491Coins
    thanks for taking a moment to clarify CoG. @pmvcda :thumbs
  3. wannabeaflyer2
    london uk
    8,346Coins
    Hi @pmvcda we read the sign that said" Genius at work do not disturb " LOL so we know good things are coning :) it takes as long as it takes , so we understand ...
    would be lying if i did not admit to being excited and cant wait to test out next update. But Only when your ready :)
    • Agree Agree x 4
  4. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    Any news from P3d FFB variables for ground “roughness” ?
  5. pmvcda
    15,458Coins
    I already have the plan.
    And started working on it.
    We are getting an extra filter and info for each wheel.
    It's going to work for all games that have the info on type of ground for each wheel.
  6. pmvcda
    15,458Coins
    New basic pose almost done!
    Only missing a button to convert it to advanced pose (advanced to basic is not possible)
    • Like Like x 5
  7. deadlymanager
    deadlymanager Member
    9Coins
    I'm sorry, but last update not recieve any data from DCS. And FSX tell me "cannot find simconnect" I have FSX Steam Edition and SimConnect update made automaticaly. What I do wrong?
  8. hannibal
    4,491Coins
    i havent worked with FSX
    have you copied the Export.lua file in this folder, to c:\Users\pedro\Saved Games\DCS\Scripts\Export.lua ?
    @deadlymanager
  9. deadlymanager
    9Coins
    Yes. I copy lua script file in this folder. DCS send all data I see it in another program. But Flypt not work.
  10. Historiker
    9,208Coins
    Mover is not working with DCS currently. It is something that @pmvcda is aware of and has indicated that the fix is in the next update.
    No idea why FSX does not work, sorry.
    I use Mover with DCS by using the Simtools input and Dirty's DCS Plugin.
  11. pmvcda
    15,458Coins
    @deadlymanager and @Historiker,
    FSX is not working, because it needs to work with the 32 bit version of mover.
    It's also necessary to install the SDK and redist 32 bit from Microsoft.
    Better wait for 2.9. It has a new dll and a complete guide for instalation.
    I'm still adding features to that and p3d.
    DCS is the same. Please be patient. 2.9 has to be released till the end of the month.
    It's my deadline, even with some bugs.
  12. robjos1
    robjos1 Member
    Flying about
    United Kingdom
    30Coins
    Keep up the great work. can't wait to try Mover 2.9. I setup a couple of ESP32 with your code the other day and they all connected and seem to work flawlessly. Now I'm milling out some circuit boards (single sided so flying wires everywhere!) to get the level converters done.
  13. deadlymanager
    9Coins
    I'll be waiting!!!! Super
  14. pmvcda
    15,458Coins
    Seems there's no progress... But I'm all over it:
    For 2.9, we can now:
    - Select the modules we want to open/merge
    - Associate the *.Mover file to the Mover executable
    - Select shortcuts to start/stop outputs and sources
    - Also checks for outputs connected to ensure we don't change profiles with them connected
    • Like Like x 5
  15. OneDadz
    OneDadz New Member
    87Coins
    Hello FlyPT, thank you very much for what you are doing. I can't wait to be able to test your software on my simulator.
    I would have liked to know if you had the possibility of adding Richars Burns Rally, in your list of compatible games?
    And also know if you could add the understeer function?
    Thanks,,
    Dadz
  16. pmvcda
    15,458Coins
    Hi, thank's.
    For RBR, we have to search for memory hooks. It takes so much time, can't promise to make it soon.
    If anyone has it and wants to share, it will be fast to add RBR.
    Meanwhile, I added ETS2 (and AMTS) for 2.9:
  17. cfischer
    Colorado
    2,783Coins
  18. pmvcda
    15,458Coins
  19. cfischer
    Colorado
    2,783Coins
    I've been waiting and hoping for a WRC8 plugin for simtools. Since you're going strong making all these plugins natively maybe you could take a look at that game. I don't want to put more on your plate though. So impressive what you've accomplished so far.
    Really looking forward to 2.9 - changing the suspension gain with the speed of the vehicle. It will be great to finally have a good sense of speed!
  20. vulbas
    vulbas Active Member
    france
    1,101Coins
    AC motor, 6DOF
    I am testing flypt.
    what is "extra" on the image?
    Thank you for your help
