Showroom 2/3DOF Flight sim first build
Discussion in 'DIY Motion Simulator Projects' started by Typhoon56, Jan 5, 2020.
  1. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    Not sure if this will help but this is how mine is wired. Works without a hitch. I run 24v. No resistors on the sabertooth. No heat issues at all. Use one single 80mm fan blowing down on all both cards.
  2. Typhoon56
    Typhoon56 Member
    Engineering
    Cambridge
    400Coins
    2DOF, 3DOF, AC motor, Arduino
    Thanks for the reply, il have another look tomorrow morning and probably remove the resistors see what happens.
  3. Menix
    Menix Member Gold Contributor
    107Coins
    Why not try the Kangaroo X2
    i have best results and easy configuration.
  4. Typhoon56
    Typhoon56 Member
    Engineering
    Cambridge
    400Coins
    Ok so it turns out you need to remove the DC ground in each power supply, not just one like I did.
    So got everything working, but even with the new power supply it's still struggling to push the rig back up, nothing is tripping out or getting hot.
    Any suggestions ? Or am I just looking at the rig being to heavy ?
  5. Typhoon56
    Typhoon56 Member
    Engineering
    Cambridge
    400Coins
    So I cracked it, turns out my sabertooth was limited to only 10A in the DEscribe software so cranked the current limit up to 50A, uploaded to the sabertooth board and now the rig has amply power to move it.
  6. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    Glad you figured it out. Should upload a video of it in action when you get it fine tuned.
  7. Typhoon56
    Typhoon56 Member
    Engineering
    Cambridge
    400Coins
    Yes I plan on posting a video once iv fine tuned it.
  8. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    Making any headway? Is it still functioning well with the server power supplies?
  9. Typhoon56
    Typhoon56 Member
    Engineering
    Cambridge
    400Coins
    Yeah it's still functioning correctly , not had any real time to properly tweak it yet, one thing I did notice is the direction of movement is opposite to what game is doing, but I'm sure I read somewhere that it's meant to be like this ? Is that correct ?
  10. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    You either have your pots or motors wired backwards if I remember correctly. Same thing happened to me initially.
  11. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    Hello Friend,
    good project looking at your simulator also notice that your joystick is modified I would like to know how I did it I have a x56 hotas rhino from saitek and I would like to extend it would you have any ideas?
