Help with 2 Kangaroos
Discussion in 'SimTools compatible interfaces' started by Menix, Mar 1, 2020.
  1. Menix
    Menix Member Gold Contributor
    117Coins
    Hi
    please help me
    i changed my rig to a 3dof. Using 2 kangaroos x2 and 2 sabertooth.
    i assigned interface 1 at com 8 and interface 2 com 7
    But i dont know how to mix this both interface for output testing or games.
  2. Menix
    117Coins
    Find it out.
    I copied the String from Interface 1 to 2.
    But my 3 axis is Nr. 3a that was my mistake.
  3. Menix
    117Coins
    i Have another Question, postet in Kangaroo Tutorial but no one answers.
    What have i to type in shutdown sequence with the Kangaroo Interface when i want that my rig goes the pitch axis (axis 2) goes down to pot position 4500 mv?
    So its easyer for me to get in the rig.
    I dont know what the <10><13> means, i know that a command should looks like p,4500 but how to corrcet type in in the shutdown Sequence ?
  4. BlazinH
    16,665Coins
    If pitch is on motor 1 then use 1,p4500<13><10> otherwise use 2,p4500<13><10>. 13 is ASCII code for a carriage return and 10 for a line feed. This code is required after a command to actually execute it on the kangaroo. It emulates how old mainframe computer systems that used terminals worked. Therefore you can control a kangaroo directly using a terminal emulator also.
  5. Menix
    117Coins
    Thx for Answer i will try it tomorrow
  6. Menix
    117Coins
    dont work
    my shutdownsequence is
    1,powerdown<13><10>2,p3500<13><10>2,powerdown<13><10>
  7. JAD
    JAD Active Member
    Australia
    1,446Coins
    The stop string is sent all at once and there isnt time for the 2,position command to goto the position before it gets the 2,powerdown instruction. I tried to find a kangaroo instruction for waiting but couldnt find one.
    I have the same scenario as you and I didnt end up using the start and stop strings in simtools.
    Here is a explainer of what I did in lieu in a previous post.
    https://www.xsimulator.net/community/threads/hoddems-diy-linear-actuator.10324/page-15#post-186205
    Since that post, Ive used JoyToKey to bind joystick buttons to the FoxTerm files to run them with a button press. Ive used 4 buttoms on the gear stick for this.
    The left button in the picture, SHP, is start>home>park macro. The Park is set for the bottom to get in and out. Ready is mid height ready for the simtools or flypt to takeover from.
    PD is powerdown. I just have to remember to park it before I powerdown as it gets a bit of speed back driving from the mid point to the bottom crash limit.
