Question DCS profile editor no GameVibe or GameDash
Discussion in 'Digital Combat Simulators (DCS)' started by Bangkok Aerospace, Feb 29, 2020.
  1. Bangkok Aerospace
    Bangkok Aerospace New Member
    - 49Coins
    In tuning center they have output but I can't get axis data from Network UDP. I use DCS_GamePlugin_EXPERIMENTAL v0.06 plugin
    For another game I don't have any problem,I can get all axis data
    153,884Coins
    +11,154 / 57 / -2
  3. jakkrich
    jakkrich New Member
    Bangkok Thailand
    57Coins
    I have a problem that DCS plugin didn't send Axis data via Network UDP. For other game I can't get it only DCS didn't work.
    Tuning Center have value of Yaw, Pitch, Roll ....... but no Axis data send through interface
  4. Dirty
    All the way up front.
    7,971Coins
    Indeed, as far as I know GameDash and GameVibe are not supported in the Experimental DCS plugin I made. To be honest, I don't even know exactly what they are :) I mean, I heard those names before, but since I don't use SimTools I never invested the time to get familiar with everything going on "around" SimTools. I just assumed that the data in the 3 Extra slots could be used for anything.
    I will take a look at the code again to see if I can add GameDash and GameVibe support. Is there example code around somewhere from a plugin that uses GD or GV?
    153,884Coins
    +11,154 / 57 / -2
    @yobuddy or @value1 can give advice on implementation.
  6. yobuddy
    51,535Coins
    Both GameDash and GameVibe have a var to turn them on.
    Here is GameDash's
    "Private Const _Enable_DashBoard As Boolean = True"
    Then you just assign inputs, much like the motion stuff.
    Code:
    'Dash
    Dash_1_Output = "Speed," & .Speed.ToString
    Dash_2_Output = "Gear," & .Gear.ToString
    Dash_3_Output = "RPM," & RPM.ToString
    'Vibe
    Vibe_1_Output = "Rpm," & RPM.ToString
    Vibe_2_Output = "Gear Shift," & .Gear.ToString
    Vibe_3_Output = "Collision L/R," & .GForceLatitudinal.ToString
    Vibe_4_Output = "Collision F/B," & .GForceLongitudinal.ToString
    Vibe_5_Output = "Road Detail," & HeaveAcc.ToString
    Let me know if you need a hand buddy.
    take care,
