My project 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Arielnac, May 19, 2019.
  1. wison
    wison New Member
    - 885Coins
    hi Arielnac,
    which hall sensor and pulley you are recommend, 180 or 360 pulley 40-20 or 60-30
  2. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi.
    Will you use the same engines ????
    I believe that the 360º sensor has a higher resolution than the 180º sensor, since the 4096 positions of the sensor are distributed in double the route.
    I have limited axes in simtools at 85% so that of the 360º of the sensor 306º are used. There are 27º of each side as safety limits so that the sensor does not complete a turn.
    I used pulleys of 40 teeth and 20 teeth with GT2 belt 6mm wide and 200mm long. The motor shaft is 17mm wide, so the 40-tooth poles are very fair when the central hole is enlarged. I could do it but you have to be very precise. Maybe it's better to use a 60-30 pulley ratio and longer belts.
    60 teeth pulleys with 17mm hole are obtained.
  3. wison
    wison New Member
    - 885Coins
    Thank you.
  4. iLLuac4
    iLLuac4 Active Member
    885Coins
    Hi. I am having problems with my engine. Pots are working engines spin but only near the limit of 5v. If I select Motion in smc3 util nothing happens. What settings did you use in smc3 utils for those motors. I am atm clueless. Have tried also different arduino but the same results.
  5. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi. Are you using BTS7960 ???? You set MODE2 in the line of code for the arduino ???
  6. iLLuac4
    885Coins
    Yes I did. Can you screenshot the settings of your motors from SmcUtils please?
  7. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Keep in mind that SMC3 is a software for testing and its use can burn the BTS7960 even without load on the motor shafts, since it can generate very sudden movements of them. For example, if you use the maximum power and generate a sharp change in the direction of the motors.
      80.2 KB
      673
  8. iLLuac4
    885Coins
    TNX. I was able to get one working. The other one is still a mistery. Hall sensor seems to work but motor spins only in one direction. Will try with spare BTS7960. It is also funny that I have burned the fuses on the motor that I have implemented in my setup on one motor. Will troubleshoot further.
  9. Arielnac
    Arielnac Member
    Argentina
    240Coins
    If the engine only makes movements in one direction, it is because one of the BTS 7960 chips of the IBT-2 was burned. That's why I told you to be careful when using the SMC3. I advise you to work with 18V unless you are going to burn the IBT-2 when using simtools.
  10. Arielnac
    Arielnac Member
    Argentina
    240Coins
    New video with Asseto Corsa and the 2DOF simulator
  11. iLLuac4
    885Coins
    It seems that ibts were burned. The new one seems to work.
    How do you manage those motors when the computer turnes on? Because those motors do not hold the position. Is it possible to center them when the computer powers on or. is the simulator needs to be started?
    P.S.:
    Did you reverse the polarity of the motors, because I have read that if using hall sensors is different when using pots?
    Also do your motor make any small movement when connected to arduino on computer powers on?
  12. Arielnac
    Arielnac Member
    Argentina
    240Coins
    What you should do is first turn on the computer, once I load simtools, just there you have to energize the power supply. The motors are going to position themselves in the neutral position.
    The motors in this case do not have a specific polarity. The polarity will be given by the correct movement of the axis with respect to the sensors
    So that the axes do not have that small movement, there must be a little load on the lever. When you have the platform mounted you have to look for some weight. that will neutralize the small slack of the engines.
  13. iLLuac4
    885Coins
    Hmmm interesting.
    It could be possible to automate the proces. First auto start simtools and then the script could turn on the power supply. With this device and tasmota firmware it should be possible to do it.
    https://www.banggood.com/custlink/GmK3s2GdL4 or. easier https://www.banggood.com/custlink/vmKvAqmdaU
    https://github.com/arendst/Tasmota/wiki/blitzwolf-SHP6
    https://github.com/arendst/Tasmota/wiki/commands
    I was able to test it in Game Engine now. To which commands it shoud react 2DOF (Pitch and roll) or anything else?
  14. Arielnac
    Arielnac Member
    Argentina
    240Coins
    I prefer to do it manually, it is no problem to do it and it gives me the assurance that the motors receive energy once simtools tells arduino what the neutral position is.
    Just there I get on the platform.
    The neutral position is given by the axes setting, usually at 128 which corresponds to the 2.5V of the sensors.
  15. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Thank you very much Arielnac. That fourth picture gave my a possible way to fix the motors in my still to build rig.
    Once I start building I will refer to your thread. By the way I love your idea in wood. I will have some metal trash and wood to build with. An as I am not owner of a welding machine you helped me with your idea of holding the motors.
    GRACiAS SENOR :)
  16. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Hey Arielnac. I just wanted to say thanks for posting this project. It has helped me a lot with my 2dof.
  17. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi. Are you using the same engines ????
  18. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi. I'm glad that there served you.
  19. Keith
    Keith Active Member
    Electrician
    154Coins
    Yup. Same motors and same sensors
  20. Keith
    Keith Active Member
    Electrician
    154Coins
    How's it going Arielnac? Did you end up installing rubber bands on your platform?
