Question Simtools Output Testing problems
Discussion in 'New users start here - FAQ' started by jonas bandier, Mar 10, 2020.
  1. jonas bandier
    jonas bandier Member
    272Coins
    Hi there!
    I am trying to get an output from simtools but it does not seem to work. I think it has something to do with the Interface - Output in the Interface Settings tab. I have gotten motion out from the SMC3Utils program, i can move the motors just fine from there, but not from the simtools software.
    I have already tried a couple of different codes that i found on the forum.
    The rig is a 2Dof and I'm using one Dual VNH5019 motor driver board with two motors and one arduino.
    153,986Coins
    +11,162 / 57 / -2
    Setup for Simtools 2 is very straight forward, so change to 10bit binary and add Interface Output depending on how many axis you have:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Set for 10bit binary output
  3. jonas bandier
    272Coins
    Oh, thank you so much!
    It's amazing how helpful this forum/community is for newbies like me.
  4. jonas bandier
    272Coins
    Hi again.
    I have gotten the motor to move and i am now trying to get data out of LFS. I am quite confused about the game manager because is says in the top right corner "patched", but in the game patching tab is says "patch required". When i then click on the LFS installation directory it comes up with this error message (Pictures below).
    Thanks.
    153,986Coins
    +11,162 / 57 / -2
    Please expand the error message and copy and past the error message here.
    Be aware that LFS has to be run before it is patched, see here for details: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.345/
  6. jonas bandier
    272Coins
    Hi noorbeast
    I have done the LFS thing.
    The error message first pops up the i open game engine.
    It looks like this:
    System.ComponentModel.Win32Exception (0x80004005): Adgang nægtet
    at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.4.0
    Win32 Version: 0.2.4.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    EwaRlRjyQRIFJmdLrQQpzimRMOv
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/Jonas/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
    153,986Coins
    +11,162 / 57 / -2
    I believe that message relates to access denied, is that correct @yobuddy?
    Try running SimTools as admin and see what happens @jonas bandier.
  8. jonas bandier
    272Coins
    @noorbeast
    I tried running it as administrator, now it says (Translated from danish)
    "Only a part of ReadProcessMemory- or WriteProcessMemory-
    the request succeeded" instead of "access denied"
    Error message:
    System.ComponentModel.Win32Exception (0x80004005): Kun en del af ReadProcessMemory- eller WriteProcessMemory- anmodningen blev gennemført
    mscorlib
    System
    System.Core
    System.Drawing
    System.Xml
    Game_PluginAPI
    enabled.
    For example:
    <configuration>
    </configuration>
  9. yobuddy
    51,563Coins
    Correct.
    Personally I would uninstall and reinstall a fresh copy of simtools.
    I have to believe the installation didn't go quite right with all the errors your having.
    Take care,
  10. jonas bandier
    272Coins
    @yobuddy
    Thanks, i reinstalled it at now it works!
    Strange because i had already triet reinstalling SimTools... but now it works and i am happy!
    Here in some pictures of my design (still work in progress):
    Question: what is most important? Greater angle = higher "g force" but slower response or, less angle = lower "g force" but quicker response?
  11. yobuddy
    51,563Coins
    Less angle = lower "g force", but quicker response for sure!
    Glad your up and running buddy!
    Take care,
  12. dieser
    dieser Member
    372Coins
    great progress!
    seems to run fine without load in the video! :)
    i‘m building a very similar seatmover at the moment.
    what exactly do you mean with greater and less angle? the position of the motorshaft to your seat?
    greets
    dieser
  13. jonas bandier
    272Coins
  14. donottellmywife
    donottellmywife Member Gold Contributor
    Something something tech related
    424Coins
    So for a 3DoF you need just those 3 or do you need additional ones?
    153,986Coins
    +11,162 / 57 / -2
    3 is the maximum axis for SMC3 and one control board.
