Another 6DOF worm gear project
Discussion in 'DIY Motion Simulator Projects' started by Bo Howell, Mar 15, 2020.
  1. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    It’s alive! Lots of tuning to do. But it’s moving under its own power. A863938F-C563-4993-A8F2-9CE64051E890.jpeg C4179F0A-3E67-40C5-82D5-EB529557DEC6.jpeg 3AD38AA7-2920-437B-B9E6-48224199B89C.jpeg B6BCF148-2D02-4B4E-AA77-6DF2B3125474.jpeg
  2. Pit
    30,513Coins
    Hi Bo, congrats, very good work in very short time.
    Before you are going to test the rig check out if all is working fine so far. That said, if one motor is not working properly you rig could be damaged. Probably the lever could be too long, the motors are not so powerful holding the weight of you and your seat, not to mention if you are racing over bumps and curbs...:) Good luck anyway.
    EDIT: you are on a flight sim, so slower moves are to be expected.
  3. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    First video of it moving while playing with tuning.
    154,370Coins
    +11,179 / 57 / -2
    Great to see your rig in action :thumbs
    How thick are the rods, as they will be subject to considerable loads?
  5. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    Thank you.
    The rods are 1/2” or about 13mm in diameter.
    They will carry my heavy arse (200lbs or 90kg) quite well so far. But I am awaiting three gas springs to take some of the load and help the motors a bit.
    154,370Coins
    +11,179 / 57 / -2
    It will be interesting to see how the rods hold up over time.
    Personally I would slip over some steel tubing with large washer and lock nuts either end to provide addition strength.
  7. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    @noorbeast I will certainly plan on that if they look like they are starting to bend. Thank you for the idea!
    I am very surprised by the power of these motors. I have the arms set at 101.6mm
    (4 inches) CTC and the power is fantastic! The motors do get hot after a little while with me on it. Therefore I am installing the gas springs before I damage something.
  8. Pit
    30,513Coins
    To be honest at the latest when he adds the pedals.
    @Bo Howell Gas springs may help, on the other hand they have a maximum rate of cycles per minute (possibility of overheating, loss of pressure etc.)
  9. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    We are starting to get the tuning dialed in for Xplane 11!
    This is my oldest taking it for a spin.
  10. Squarebob
    Squarebob Member Gold Contributor
    Georgia USA
    70Coins
    DC motor, Arduino, 4DOF
    Nice work. very much like the unit I want to build. My motors are rated 24volt 200 watts continuous and 1200watts peak.I may have lots of questions when I get my build going
  11. Bo Howell
    Bo Howell Member
    Product Specialist
    New Sharon, Iowa
    119Coins
    Absolutely! Just let me know.
    I apologize I haven’t been on here much the last few days. I’ve been playing and tuning on the profiles.
    It is so much fun!
  12. freemindkkk
    freemindkkk New Member
    16Coins
    Do the motors of your motion platform move down when they are off?
