2DOF,3DOF,4DOF,6DOF Homemade Actuator
Discussion in 'Motor actuators and drivers' started by Ivan Zaharov, Nov 9, 2019.
  1. Ivan Zaharov
    Ivan Zaharov Member Gold Contributor
    Industrial repair CNC
    Latvija
    229Coins
    2DOF, AC motor, Arduino, Motion platform, 6DOF
    The Chinese sent not good pulleys. I will try others. The microphone on the cellphone is very sensitive.
  2. Ivan Zaharov
    Latvija
    229Coins
    Hello. I finished all the actuators. Now you can build the platform. I will describe the platform in a new topic.
  3. Gadget999
    12,035Coins
    What type of servo motor did you use ?
  4. Thanos
    Electronics Engineer
    2,862Coins
    AASD-15A, but 80 flange I think...
  5. Ivan Zaharov
    Latvija
    229Coins
    I used engines 80SY-M04025 4Nm encoder 5000 pulses per revolution.
  6. Ivan Zaharov
    Latvija
    229Coins
  7. Deleted member 37105
    Thank you for sharing. How much does an actuator cost?
  8. Ivan Zaharov
    Latvija
    229Coins
    Hello .Cost approximately 1000 eur per 1 piece.
  9. Ivan Zaharov
    Latvija
    229Coins
    Everything happened. I set up a simulator. I decided so far to limit the progress of the actuators to 200mm. I decided that there will be a lot of 480mm. Later I will try at 480mm. While I'm using SimTools, then I'll try on FlyPt.
    • Winner Winner x 4
  10. Thanos
    2,862Coins
    Well done!! Looks amazing, especially that large sway motion!!!!
  11. Ivan Zaharov
    Latvija
    229Coins
    I think that they can start building simulators, actuators and platforms in a commercial version. Equipment and manufacturing capabilities are. Actuators get very reliable and strong.
  12. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    hello Ivan. congratulations first of all for your project. I too am thinking of making an actuator similar to yours but with a stroke of 150mm. Also I would like to use 80ST-M02430 motors. I'd like to ask you a question. What type of toothed pulley do you suggest? HTD 3m, HTD 5m - GT, GT2?
  13. yondwangmms
    yondwangmms Member
    - 148Coins
    Very beautiful design, but the price of a single 1000 euro is still too expensive!
