Question Issue with connetion belt tightener
Discussion in 'SimTools DIY Version' started by Armin Schmidt, Jan 23, 2020.
  1. Armin Schmidt
    Armin Schmidt New Member
    80Coins
    2DOF, 3DOF
    Hy guys, im running an belt tightener for my racing sims, its an china-adruino with two servos and and extra power supply. problem is i plug it in it runs fine for about 5 minutes then it tightens but dont let go anymore. only when im unplugging it it works again. can you help me with that
    thanks
  2. Zed
    USA
    5,841Coins
    Do you have the source code for the program the Arduino is running? There was another guy here who had what sounds like a similar issue in his wind Arduino. Turned out his system was especially sensitive to the input routine in the Arduino.
    The code in this post fixed it for him. With the source code for yours you could adapt what I did here into it. Can’t say that this is your issue but it could be something about USB now may be interacting with the way the original routine handled input. Your symptoms at least sound similar. If you look a few posts before this one you can see how he described his symptoms and see if this might be worth pursuing.
    https://www.xsimulator.net/communit...rmoto-and-arduinouno.6876/page-31#post-190754
  3. Armin Schmidt
    80Coins
    2DOF, 3DOF
    Wow, i didnt thought i would get that fast a reply and help. Id worked perfectly! Thanks
  4. Zed
    USA
    5,841Coins
    Armin, you mean substituting the input routine for the one in your code fixed the issue?
  5. Armin Schmidt
    80Coins
    2DOF, 3DOF
    Exactly. It wasnt the one from this forum but on virtualracing.org there is on the forum a thread with a code for this, just replaced it and it worked! Had a race yesterday for about an hour everything worked fine!
  6. Zed
    USA
    5,841Coins
    Hey Armin, that’s great! Glad it helped!
    Would you mind posting the input routine as you used in the belt tightener program?
    Are you using Sim Tools and Game Dash or just Sim Tools?
    I'm asking because I’m working on another issue. Thanks!
  7. Armin Schmidt
    80Coins
    2DOF, 3DOF
    Hey, yeah sure. Sorry for the late reply
    We used this file
    RC Model Code for Arduino UNO - 2DOF - Expandable 2.0
    From this forum
    And the rc modelsimtoolsmode.ino in the .rar
  8. Zed
    USA
    5,841Coins
    Thanks!
  9. Armin Schmidt
    80Coins
    2DOF, 3DOF
    Hy, im sorry but i need to ask another thing. ive reinstalled my pc cause of gpu issues. i reinstalled simtools and dame mangaer. placed setting in simtools. it works when i test output in the software.
    put the file in plugin manager installed it. patched it also. but it doesnt work ingame. im sure im just forgettibg something. but got no ide what. could you help me with that?
    Thank.
    btw. when the game is running looks like this
  10. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,507Coins
    Check that you have the axis settings saved under assetto corsa competizione and not just the default game profile.
  11. Armin Schmidt
    80Coins
    2DOF, 3DOF
    How do i do that?
  12. GWiz
    GWiz Active Member
    Dentist
    1,507Coins
    Click on Axis assignments on the left and you should be able to select assetto corsa competizione under the Game list via the drop down. The Output testing only checks the default profile.
  13. Armin Schmidt
    80Coins
    2DOF, 3DOF
    i have...still....
  14. GWiz
    GWiz Active Member
    Dentist
    1,507Coins
    The only other thing I can think of is to try un-patching and then re-patching the game.
  15. Armin Schmidt
    80Coins
    2DOF, 3DOF
    i tried. did you copy the whole content from the file in simtools folder? the minmax and Banner?
    When i choose competizione on Game Manager profile editor it shows no graph. bur it did before
  16. Armin Schmidt
    80Coins
    2DOF, 3DOF
    Yep, thats it. I opened the folder with the plugin and put it in the plugin updater. And didnt put the whole folder in plugin updater. Had to read the manual to learn it. Sorry my bad.
