Linear coil motor !
Discussion in 'Motor actuators and drivers' started by Gadget999, Feb 15, 2020.
  1. Gadget999
    12,035Coins
    I got given some coils a few days ago and o wondered if i could use them on a sim
    They have a pull of around 200N at 4 amps
    The coils look rugged and may take more current / voltage
    I rigged up an arduino and a linear pot with a st motordriver and the smc3 software
    It works !
    The motion is only in one direction, the rubber gaitor pulls the plunger back out.
    I will fit a spring to push the coil back out.
    If there was a magnet on the plunger i could drive the motor in and out
  2. Mike5050
    Mike5050 New Member
    Chiropractor
    New Jersey
    271Coins
    If i'm correct coils will not stop in degrees only full in or full out.
    It would make a very violent bumpy ride lol
    I will be following to see if you get the coils to work, good luck.
  3. Gadget999
    12,035Coins
    no they can be stopped in position depending on how much current you have
    the coils i tested were pull only and returned using a spring
    i have since ordered some magnets so the coils can push and pull :)
  4. Mike5050
    Mike5050 New Member
    Chiropractor
    New Jersey
    271Coins
    I not sure how well it would work due to the current needed to hold the rod in place at different intervals.
    Maybe if you had springs on both ends or multiple coils for each amount of travel you want .
    I wish you all the luck with your project and hope you get it to work the way you want.
