value1
Raceroom Racing Experience Plugin 2.0.7.1
SimTools game plugin for Raceroom Racing Experience
  1. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Another request: Since game currently does not implement cooldown lap, would be nice if motion is stopped after s/f line crossing in the Race.
  2. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    86Coins
    I'd like to know if the plugin is ok to RACEROOM DTM experience 2015 too.
    Best Regards
    Francesco
  3. FrancescoRoberto
    Italia
    86Coins
    Thanks, I like the DTM cars so I find race room like a game which there are these cars in.
    But I understand that you prefer Assetto corsa like simulation game.
    Best Regards
  4. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    I did not try, but someone on S3 forum mentioned that cars that did not receive physics update, still have oscillation issues.
    @FrancescoRoberto You can also experience DTM in rF2 (URD T5 with skin pack). It doesn't look as good as R3E, but physics are way more detailed (especially in terms of motion), and cars are fragile, lose doors, wheels, wings. But, rf2 is not everyone's cup of tea :) hopefully R3E DTM will get update soon
  5. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    I cannot get the plugin to work. can somebody please advise.
    simtools gamemanager is not recognizing that raceroom is running.
    are there some settings in raceroom i need to change ?
  6. nornesnaj
    Netherlands, Zelhem
    125Coins
    I use Race Room Experience build 0.9.0.0937 (treid both 32bit and 64bit)
    RaceRoomRacingExperience_Plugin.2.0.7.1
  7. nornesnaj
    Netherlands, Zelhem
    125Coins
    still not working closed all other applications
    only simtools etc. and raceroom. still nothing.
    151,979Coins
    +11,061 / 56 / -2
    It may help if you also post pictures of all of your settings.
    Just checking the obvious, but to be sure can you please confirm you are using the
    pro version of SimTools, do other games work fine?
  9. nornesnaj
    Netherlands, Zelhem
    125Coins
    Ive solved the problem made dumb mistake forgot to patch :):)
    now its working thanks
  10. jeanmehdi
    jeanmehdi New Member
    LONDON
    - 201Coins
    Just what i needed thanks!!!!
  11. bruno1210
    bruno1210 schumi06
    103Coins
    also works very well thank you very much.
  12. GiovanniPofi
    GiovanniPofi New Member Gold Contributor
    - 94Coins
    Hello, do you know where I can download the raceroom plugins for simtools, can you also give me some help for the installation?
  13. noorbeast
    151,979Coins
    +11,061 / 56 / -2
    All plugins can be found here: https://www.xsimulator.net/community/marketplace/
    Including RRE: https://www.xsimulator.net/community/marketplace/raceroom-racing-experience-plugin.36/
    See the FAQs re plugin installation: https://www.xsimulator.net/community/faq/how-to-install-plugins.310/
    And refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  14. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    Motion platform, 6DOF
    I'd like to report a problem with this plugin in the hope someone can make the quick change.
    SimTools doesn't stop the motion while in replays, causing all sorts of issues (can't control my mouse and keyboard since I'm being thrown around and can't' stop the replay because I can't control my mouse, etc...)
    ISSUE
    RRE plugin doesn't respect the Line 686 of the shared memory output says gameinreplay true/false.
    Thanks.
  15. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    I don't see this plugin in SimTools 3.0. Does it need a new version to be compatible or can I install the 2.x version of the plugin in ST 3.0?
  16. Historiker
    9,208Coins
    Simtools 2 plugins are not compatible with Simtools 3
  17. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    Too bad.... I can't use SimTools 3.0 until an RRE plugins comes out then.
