DCS and Tuning Center 2020
Discussion in 'Digital Combat Simulators (DCS)' started by Ozbroux, Apr 6, 2020.
  1. Ozbroux
    Ozbroux New Member
    148Coins
    Hi :)
    I can't get the tuning center to work, when I launch the game I get an error message (one of your interface requieres GameEngine to be restarted. Please Restart GameEngine)
    Can someone explain to me the procedure (from the beginning) step by step?
    Thank you so much
    153,788Coins
    +11,150 / 57 / -2
    Normally you will get this message if an SCN can't startup, or has not initialized.
    Are you using a single serial converter, or do they both have their own adapter?
  3. Ozbroux
    Ozbroux New Member
    148Coins
    Hello @noorbeast
    I have no hardware connected, I just have a PC with two screens. What is a SCN?
    I relaunch GameEngine and as soon as I launch the game, it gives me the message.
  4. Ozbroux
    Ozbroux New Member
    148Coins
    Is there a tutorial on the forum? I haven't seen anything recent, I found an old post but it doesn't work: /
  5. Ozbroux
    Ozbroux New Member
    148Coins
    I deactivated the outputs on game engine, more error, tuning center automatically recognizes that I launched DCS, but game data input remains at zero. What does "balance capture OFF" say?
    Thank you.
    153,788Coins
    +11,150 / 57 / -2
    Can you lease post details of your rigs hardware and pictures of all of your settings.
  7. Ozbroux
    Ozbroux New Member
    148Coins
  8. Ozbroux
    Ozbroux New Member
    148Coins
    I just tested with beamng and it's the same. thank you for your help
    153,788Coins
    +11,150 / 57 / -2
  10. Ozbroux
    Ozbroux New Member
    148Coins
    Thank you :)
  11. Ozbroux
    Ozbroux New Member
    148Coins
    it doesn't even work with both methods :(
    153,788Coins
    +11,150 / 57 / -2
    What are your Interface Settings and Axis Assignments, please post pictures.
  13. Ozbroux
    Ozbroux New Member
    148Coins
    Thank you
    153,788Coins
    +11,150 / 57 / -2
    Please post pictures of your rig and details of the hardware and code being used.
    The rig must be calibrated and move as expected with the code being used, before moving on to SimTools configuration.
    With SimTools the Default Profile must be configured, and this is what SimTools expects in terms of configuration: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    The rig should then be tested using Output Testing and move as expected before moving on to patching a game and refining a motion profile.
    Here are some tips for refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
