Question Parts Verification
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Grimspyder, Apr 7, 2020.
  1. Grimspyder
    Grimspyder New Member Gold Contributor
    146Coins
    I'm planning to build a 3DOF seat mover, and eventually use the parts to build a full frame 6DOF.
    Currently I want to build a working test model with all the parts minus the actual motors, and use a servo to make sure everything is working correctly then, Ill order the motors and begin the actual seat mover.
    These are the part I wanted to use for the electrical / control portion. Just wanted to make sure these parts would work before ordering them
  2. Mike5050
    Mike5050 New Member
    Chiropractor
    New Jersey
    271Coins
    What motors do you plan to use?
  3. Grimspyder
    146Coins
    I'm not sure yet. So from what i'm understanding a lot goes into deciding what motors to use, like wight of the platform, weight of the person, weight of the equipment on the platform, length of the of the crank arm, the design platform.
    I do know that it will be mainly a flight Sim and of course a driving sim now and again.
    So i wanted the parts i bought to handle a few motor options.
    I should have added that I will be using marine batteries and possibly capacitors in conjunction with the PSU to drive the motors.
    Attached is the PSU specs. So I'm limited to 12V motors. Also ill be using 220V on two separate breakers to power everything. HP Moition SIM PSU_spec2.jpg HP Moition SIM PSU.jpg
    One last thing, If needed i'll use Gas Struts if weight becomes an issue, for the motors.
  4. SeatTime
    28,320Coins
    From experience, a good reliable DC motor setup that will support and move quickly a rigs+pilots weight turns out to be not cheap. IMO the powerful AC servo setups that are available today are a much better choice and end up being not that much more in cost once everything is taken into account. It is what I would be looking at if I had any intentions of building another standard 3DOF/6DOF motion rig. Certain worth your time to at least look into it.
  5. Mike5050
    Mike5050 New Member
    Chiropractor
    New Jersey
    271Coins
    Why do you need batteries for this setup?
  6. Grimspyder
    146Coins
    I've read that using a battery will help control voltage/amp spikes, by having the necessary power available, reduce the chance of tripping a breaker during one of those spikes.
  7. Grimspyder
    146Coins
    Ill look into it, I have read that AC motors where good options.
    I was thinking that by going DC i could add in a battery for each motor and reduce the chance of power issues. From what i've been looking at, a 6DOF rig is going to be power hungry.
  8. Grimspyder
    146Coins
    After bunch of reading I am going to stick with DC, seems like there are just better options with DC motors for speed and torque, also main reason is safety. A 12V DC system is far safer than 220V AC motor, plus the kids will be using this so, ill err on the safety side.
    But it is a good option.
  9. Grimspyder
    146Coins
    Question for the guys have used both JRK and Arduino, how did you like the each and why did you switch from one to the other?
    It seems (from what i found and read) that JRK was more popular few years ago, seems like the Arduino being used more recently.
    But' it seems that for better responsiveness and overall ease of use the JRK would be better choice, and that is mainly if your building a driving sim, where the faster speed of the JRK would work better.
    I guess the Arduino gives more flexibility.
    Just looking on what the thoughts are on each.
