value1
Forza Horizon 4 Plugin 2.0.0.0
Plugin for Forza Horizon 4
  1. DTHCR
    DTHCR New Member
    Queensland, Australia
    341Coins
    @moaale with sim tools and game engine running with the horizon4 plugin selected the game is what starts the plugin, if it works properly the game engine will have a blue bar at the top and display game running.
  2. DTHCR
    DTHCR New Member
    341Coins
    horizon4 loopback.png this is the program I used, the ip address and port are correct. attached is the program. unzip, run and select horizon4 as shown in pic, save and everything should work.
  3. DTHCR
    DTHCR New Member
    341Coins
    I believe it does both, i would try and get motion going first, then get telemetry. i only use simtools. I also have port forward 4123 set in my router( this is for running games on xbox one with sim tools on pc).
    Can you post some screen shots of your settings, some others here might be able to help.
  4. DTHCR
    DTHCR New Member
    341Coins
    I haven't changed the manager ip is stil default 127.0.0.1. you can try this plugin it has manual start like forza 7.
  5. DTHCR
    DTHCR New Member
    341Coins
    I am guessing that you are not playing on pc. I hacked the original plugin from value1 and yobuddy and changed to manual start so I could play on xbox.
    I can confirm both plugins work on pc.
  6. Sam MAHENDRA
    Sam MAHENDRA mahentheman
    Electrical Engineer
    Sydney Australia
    395Coins
    @DTHCR . Hi, I got the original plugin from value1 and yobuddy playing on PC.
    You say that you hacked the original plugin from value1 and yobuddy and changed to manual start to play on xbox.
    Could you please explain how I do the "manual start"?
  7. DTHCR
    DTHCR New Member
    341Coins
    @Sam MAHENDRA ok with my modified plugin its the same as forza7. with game engine running and game selected there will be a play button to the right as seen in the manual start pic, the second pic is after you select the play button, at the top the bar goes blue and displays game running and the button has changed to a stop button. see other pic.
    now I can play and have motion on xbox .
    or if you are trying to make your own plugin, then you need to remove the process name.
    The settings for xbox are the same as forza7, goto settings, then hud and gameplay, turn on data out, set ip to computer that's running simtools, port 4123 and save.
  8. miladsalari
    miladsalari New Member
    - 289Coins
    HI. How could find your ip
  9. DTHCR
    DTHCR New Member
    341Coins
    i hope this is what you are asking.
    Open sim tool game engine, then click on the tools button on the bottom left side, then in the top right hand corner will be the computers ip address.
  10. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
  11. fledge2b
    fledge2b New Member Gold Contributor
    Nagoya
    603Coins
    3DOF, SCN5
    I think Forza Horizon 4 is a very unique game, but in my case Simtool doesn't work and I'm having a hard time. One of the reasons is that I don't understand port fowarding, but it seems that I can't operate port fowarding on AirStation, which is the setting tool of my router Buffalo WXR-1750. In this case, do I have to replace the router?
    Also, is there an enableloopback utility that can be used on windows 10?
    If forza horizon does not appear in the list even after installing in Program Files(X86) , is the installation location wrong?
  12. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    Sorry, use Forza Horizon 4 plugin 2.0.0.2 and game setting data IP address 127.0.0.1, port 4123.
    everything OK.
  13. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Does Forza Horizon 4 still work?
    Do you have any updates or special procedures?
    I tried Enebleloopback, but the name of the game does not appear on the list.
    I downloaded what is here in the forum and the name does not appear in the list either.
    The game is on an external hard drive.
    Could this be the reason?
    Can someone help me?
    Thanks.
  14. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    107Coins
    2DOF, 3DOF, JRK
    Does anyone have this working with the Steam version?
    Like Leandro above, EnableLoopBack does not show any of the Steam Forza files for myself either.
  15. Brett
    Brett Member
    Engineer
    107Coins
    2DOF, 3DOF, JRK
    Bump. Is there anyone that has this working with the Steam version of Forza Horizon 4?
  16. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    I just read it today lol... i never use loopback !
  17. paulopsx2
    brasil
    647Coins
    try to put some infos on FH5, tomrrow and then post here.
  18. Brett
    Brett Member
    Engineer
    107Coins
    2DOF, 3DOF, JRK
    Do you have it working with the Steam version though?
  19. paulopsx2
    brasil
    647Coins
    No. only windows store
  20. paulopsx2
    brasil
    647Coins
    maybe this plugin works on FH5? I will try soon
