Installation of pc on the movement platform
Discussion in 'Commercial Simulators and Peripherie' started by djbart82, Apr 6, 2020.
  1. djbart82
    djbart82 New Member
    Operador
    28029, Madrid
    210Coins
    3DOF, Motion platform
    good afternoon
    I'm currently mounting my platform
    to save space I wanted to mount the pc on the movement platform, the set of axles is one SFX, one front and two rear
    The pc will install it with an ssd due to vibrations
    Have any of you mounted it on the platform?
    Will the computer resist vibrations?
    The motor controllers will be mounted under the seat, I imagine that being only electronic there will be no problem with them
    Thank you
    153,703Coins
    I don't think it a good idea to unnecessarily subject a computer to the type of fast motion vibrations our rigs produce, not just because of the drive, but also the wear on any type of connection.
  3. djbart82
    djbart82 New Member
    Operador
    28029, Madrid
    210Coins
    I understand that the peripherals that we install on the platform carry electronic components
    The PC that I want to install will remove everything mechanical to avoid vibrations, I will define a smooth profile, avoiding sudden movements
    I currently have the monitor on the platform with movement
    Cheers
