Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.1.0.1 pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    4,964Coins
    You have an outdated plugin, redownload the CURRENT one.
  2. john2910
    john2910 New Member
    125Coins
    I am downloading your last a serval times
  3. Wagnard
    Wagnardsoft
    4,964Coins
    If you check within the .zip you downloaded, do you see the offset xml in there?
  4. john2910
    john2910 New Member
    125Coins
    yes that's inside,and when I update the plugin with simtools and then patch I get that old config xml too and the offset xml
  5. Wagnard
    Wagnardsoft
    4,964Coins
    Just saw that you sent me the date of the CONFIG, I need the date of the OFFSET.
  6. john2910
    john2910 New Member
    125Coins
    <?xml version="1.0" encoding="UTF-8"?>
    <!-- 2020-JAN-15 -->
    <!-- Pointers by Wagnard -->
    <!-- all values in hex -->
    <!-- Force is a % valid from -32768
  7. Wagnard
    Wagnardsoft
    4,964Coins
    it's all good then.
  8. john2910
    john2910 New Member
    125Coins
    that config xml need also be in the pugin folder?
  9. Wagnard
    Wagnardsoft
    4,964Coins
    Config and offset need to be in the plugin folder.
    Also please note that you wont get movement on the *beta* version with the carrier ship.
  10. john2910
    john2910 New Member
    125Coins
    I am not on the beta,strange that it don't work for me..
  11. Wagnard
    Wagnardsoft
    4,964Coins
    while in-game (and in a ship) can you send me a picture of the simtools tuning center?
  12. john2910
    john2910 New Member
    125Coins
    Here it is
  13. Wagnard
    Wagnardsoft
    4,964Coins
    I must say that I use the Steam version. You seem with the oculus one. Maybe there is a difference.
  14. john2910
    john2910 New Member
    125Coins
    no I use the steam version,dont look at the background.. the oculus software boots up also
  15. Wagnard
    Wagnardsoft
    4,964Coins
    I'm a little out of idea, could be necessary to run as admin, you could have a security software preventing another app to check the pointers.
  16. john2910
    john2910 New Member
    125Coins
    I give up,most other games work ..But thx for your time..
  17. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    148Coins
    Hey guys. I can not get any motion in Elite Dangerous. I probably downloaded the wrong plugin or something. Here is a pic of the zip folder.
    I would try re downloading the plugin but I dont have enough coins
  18. Wagnard
    Wagnardsoft
    4,964Coins
    Yep wrong plugin.
    Also gave u some coins.
  19. Keith
    Keith Active Member
    Electrician
    148Coins
    Wow thanks Wagnard! I really appreciate that.
  20. john2910
    john2910 New Member
    125Coins
    I found out that the game manager crashes when elite dangeros starts,i copied the wow64ext.dll from simtools,but to what directory must it go? I cant find it..
