SimCalc by Tim McGuire
Discussion in 'Electronic and hardware generally' started by Tim McGuire, Jan 13, 2017.
  1. noorbeast
    152,283Coins
    +11,067 / 56 / -2
    It does run on Win 10, so perhaps the download was corrupted or you are missing something on your PC.
  2. Xesc
    Xesc New Member
    BADALONA
    149Coins
    I have downloaded once again (no corrupted file, then) but it does tha same, balck window opens...so yes, for sure something is missing in my PC but any idea what it could be?
    PC (2009) is running with Win10 64bits, 6GB RAM and Graphic card is Gforce GT710 ...
    Thanks in advacne...
    152,283Coins
    +11,067 / 56 / -2
    SimCalcs dev @Tim McGuire would be the best person to advise, when he has a spare moment.
  4. Xesc
    Xesc New Member
    BADALONA
    149Coins
    Hello I have tried to run it through CMD window and it works...;)
  5. imajavaid
    imajavaid Member
    169Coins
    how you could find the angle the lever can rotate about the motor shaft . Is there a mathematical calculation to find that angle or you can just assume the rotation of the lever.
    This angle is represented as theta(d) on Page 4, as theta on page 5 and theta(min) and theta (max) on page 9 of the document
    152,283Coins
    +11,067 / 56 / -2
    The lever rest and max angle is set in SimCalc by the user.
    As a lever traverses an arc, changing its angle, the effective utilisation of torque diminishes as it moves away from it maximum effectiveness at 90 degrees, and drops off rapidly at anything over about 38 degrees up and down.
  7. imajavaid
    imajavaid Member
    169Coins
    That's exactly my point. There is a drop of efficiency to 86% in force and speed as the lever angle reaches +/- 30 deg. So now as you have come to know that your lever should not go beyond 30 deg. Now how you can put that constraint into the design. Whether you put some hindrance in the arc of the lever to limit its motion upto 30degrees or what design parameters you have to be careful about so that automatically it should not go beyond 30 degrees.
    152,283Coins
    +11,067 / 56 / -2
    I usually suggest 38-40 degrees max, torque efficiency drops a little by then, but drops off far more above that. It is a practical compromise and still allows good motion with a suitable design.
  9. Fernando Godinho
    Fernando Godinho Member
    Entusiasta de simulação
    Brasil - São Paulo - Guarulhos
    70Coins
    2DOF, 3DOF, Arduino, Motion platform
    with this software it helped in the weight and dimension calculations I liked it very much congratulations
  10. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    Does this only work with rotational rigs or will it work with actuators as well?
    152,283Coins
    +11,067 / 56 / -2
  12. Rodeo5150
    1,251Coins
    Arduino, 6DOF
  13. Opast
    Opast New Member
    Chicago, USA
    132Coins
    Here is a fix for people when Simcalc doesn't scale/fit the screen.
    152,283Coins
    +11,067 / 56 / -2
