MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    i used 2x 12v wipermototr (Token from sunny)
    psu power supply
    arduino uno r3
    2x H-bridge
    fan
    .... help me get my diy key plz
    video soon...
    153,986Coins
    +11,162 / 57 / -2
    Have you got details and pictures of the competed rig?
  3. absyfadhel1
    bahrain
    556Coins
    i didnt understand
    153,986Coins
    +11,162 / 57 / -2
    Your thread needs to show progress of the rig until it is complete and ready for testing, because to qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the testing phase.)
    • Have been a member of the community for at least 30 days.
  5. absyfadhel1
    bahrain
    556Coins
  6. absyfadhel1
    bahrain
    556Coins
    there is no manufactures in my area ...please can you answer...is this motor good and can take weight
    153,986Coins
    +11,162 / 57 / -2
    The motor needed depends on the design and desired performance, so use SimCalc to get your head around design Vs physics Vs performance: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
  8. absyfadhel1
    bahrain
    556Coins
  9. Takumivs
    Takumivs Project CPT
    Mechatronics / Mechano Engineer
    South Africa
    38Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    is there no video for the simcal @noorbeast ? most vids i see the peeps explanation not understandable
  10. absyfadhel1
    bahrain
    556Coins
    JUST PUT YOUR MOTOR POSITION AND SOME LIKE THAT...I WANT TO KNOW WHAT MOTOR SHOULD I GET TO HELP ME...I WANT MOTOR TAKE ABOUT 200KG
  11. Takumivs
    South Africa
    38Coins
    Did you forget caps on....those motor 25nm with the gearbox can carry upto 350kgs with 25Nm. that depends on the ampts you able to supply for the motors to carry any weight the heavier the rig the more ampts you use
  12. Takumivs
    South Africa
    38Coins
    what type of rig design are you gonna use the motors on. 2dof, 3dof or 6dof?
  13. absyfadhel1
    bahrain
    556Coins
    this is my build and i just want any motor to take mor than 200kg i have 12v psu its ok?
  14. Takumivs
    South Africa
    38Coins
    the positioning of the motors are to far back. those can handle heavy weight its how you position the motors to counter the weight. im using swing gate motors and they handle up to 500kgs
  15. absyfadhel1
    bahrain
    556Coins
    can i see your build?
  16. absyfadhel1
    bahrain
    556Coins
  17. Takumivs
    South Africa
    38Coins
    automation gate motors are alot stronger look into them as they world wide available. could be your motors doesnt have power and had its days by the looks of it
  18. Takumivs
    South Africa
    38Coins
    Angle are very important
  19. absyfadhel1
    bahrain
    556Coins
    i dont have the cost for gate motor but is this gearmotor can make the same?
  20. Takumivs
    South Africa
    38Coins
    the cost of one those worm gear motors will cover two 12v motors or even 3 if you lucky. gate motor companies supply the internal 12v motors not sure about you. but here in ZA they sell to public
