Question Game Vibe Trial
Discussion in 'SimTools Pro & Entertainment Version' started by Paul Shortland, Apr 17, 2020.
  1. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Is there anyway to trial gamevibe? I was installing Simhub but it locks my Simtools output so I thought to try Gamevibe but I would like to ensure it is as i need before paying the $69.99
  2. fastvinnie
    fastvinnie New Member
    healthcare
    Amsterdam
    47Coins
    4DOF
    Hi, I have simtools and Simhub working fine together. So it is possible. Gamevibe also needs an output so I guess you are likely to have the same problem..
  3. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Interesting! I installed Simhub and it works but I get no output on Simtools for my actuators if it is running. Did you have to do anything to either to make them work together?
  4. fastvinnie
    healthcare
    Amsterdam
    47Coins
    4DOF
    I didn't do anything special, just installed Simhub. I have 5 actuators via Simtools,. and two buttkickers, two blowers and the motors from my V3 pedal set running via simhub.
    I'm not behind my gaming pc at the moment, but I can share my settings later if you want.
  5. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    That would be really useful if you could. I have a 4 actuator SFX-100 using Simtools and have just bought 2 subwoofers and an amp for Simvibe :)
  6. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Hi @fastvinnie did you get a chance to check your settings?
  7. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Ive used both simtools and simhub at the same time to with no problems at all.
    motion, game vibe and game dash all via simtools
    simhub i use a bass shaker for wheel lock on different sound card
  8. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Good to hear :)
    Still refuses to work for me. Did you change anything on either simtools or simhub to get it working?
  9. fastvinnie
    healthcare
    Amsterdam
    47Coins
    4DOF
    I'm figuring out how to post photo's.. Witch settings do you need?
    What game do you use?
    152,553Coins
    +11,087 / 56 / -2
  11. fastvinnie
    healthcare
    Amsterdam
    47Coins
    4DOF
  12. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    No both independently setup then just run at the same time.
    What game are you trying to get it to work with ?
  13. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    iRacing is the game.
    I have an SFX-100 setup using a Thanos controller with these settings.
    @noorbeast hey beast, is there a trial option for Simvibe? Feel that might work straight away?
    No options in Simhub
  14. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    do you have the diy version of simtools?
  15. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    also it might be worth while testing on a different game to see if the problem is game related
  16. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Yes I have the DIY licence. I can buy the next one up if needed but wanted to test it first ideally.
  17. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    I did read a while back that diy licence owners could get a discount on the pro version which softens the blow might be worth a pm to yobuddy
  18. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Cheers, will drop a PM!
    152,553Coins
    +11,087 / 56 / -2
    Game Vibe and all the other SimTools companion apps require the Pro license, so do not have a trial.
    But you can upgrade from the DIY to Pro SimTools license by logging into SimTools.us. There you will find an upgrade path for a DIY license to Pro for $29.99.
  20. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Perfect, thanks!
