diy 2 dof seatmover, diy hshifter and handbrake
Discussion in 'DIY Motion Simulator Projects' started by mimi67, Nov 11, 2019.
  1. mimi67
    mimi67 New Member Gold Contributor
    france
    176Coins
    Hello
    I plugged the potentiometer on the pin A11 and +5v and Gnd of the arduino, and I used the code of Wanegain on the forum PCSHM, (he planned everything:)),
    Modify the code:
    int GlobalPowerPin = A11; //use a potentiometer to define the power of the motion simulator on pin A11 (12)
    int GP_select = 1; //1:use potentiometer 0:always 100%
    double GlobalPower = 1.00; //100%
  2. dieser
    dieser Member
    372Coins
    man, this is brilliant! :)
    @noorbeast
    nobody knows this forum like you do, since i don’t know nothing about coding, wouldn‘t be great to implement such a feature to smc3 and arduino uno if it‘s possible?
    153,758Coins
    That would be something for @RufusDufus to consider re SMC3.
    @Wanegain's code is available via the FAQs, if you wanted to use it: https://www.xsimulator.net/communit...th-simukits-solution.11465/page-2#post-150402
    But honestly it is easy to set car/track specific profiles up in game manger and just select them as there as needed.
