value1
Automobilista 2 Plugin 2020-04-05
SimTools game plugin for Automobilista 2
  1. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    SCN6, Motion platform
    Is this plugin still working.
    I have patched the game and from the game options - options >system - enabled shared memory
    Project cars 2
    Project cars 2
    But no motion, is it possible the latest game patch has broken the plugin?
    Or is there something else to try
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Still works for me :thumbs
  3. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Have you captured the max min settings in TC ?
  4. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    Daguru,
    Nope, I forgot to captured the max min settings, that's probably the problem, I will give it another go tomorrow.
    Thanks,
    David
  5. patrick epps
    patrick epps New Member Gold Contributor
    - 83Coins
    what do setting in the max/min setting in stimtools
  6. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    by changing the max min settings you get faster more accurate movement
    lower the number faster the motor will move to reach the target
  7. patrick epps
    - 83Coins
    ok thank you
  8. Deleted member 4973
    Deleted member 4973
    Hi, motion working but can only get minimal motion effects no matter what values I enter. Can only feal effects Off track .
    153,920Coins
    +11,156 / 57 / -2
  10. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    Umm... Your Tune Center number should be like single digit numbers(8, 8.5, 2.4 etc). No wonder your barely getting any motion.
  11. Deleted member 4973
    Deleted member 4973
    Thanks . working now
  12. takanori
    takanori New Member Gold Contributor
    - 203Coins
    SCN5
    Hello everyone.
    I am programming in the shared memory of "Project cars 1".
    Which value should I use to calculate acceleration?
    float mOrientation [VEC_MAX];
    float mLocalVelocity [VEC_MAX];
    float mWorldVelocity [VEC_MAX];
    float mAngularVelocity [VEC_MAX];
    float mLocalAcceleration [VEC_MAX];
    float mWorldAcceleration [VEC_MAX];
    float mExtentsCentre [VEC_MAX];
    Thank you
  13. Chipless
    Chipless Member
    152Coins
    Noob question: When I plugged/patched this, it prompted me to turn on "MMF" (or so I think it was called) within the AMS2 game settings. What is MMF and where is that option found within AMS2? I've already made the system changes for Shared Memory and UDP outlined earlier in this thread, but I can't find MMF anywhere in the menu of AMS2.
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    It’s the shared memory so if you have done that your good to go :thumbs
    I would guess memory map files or function
  15. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    How do I download the plugin? I have 321 coins but the download button says "Download Not Available".
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Go here https://www.xsimulator.net/community/shop/ and buy a weeks worth of downloads :thumbs
  17. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
  18. value1
    14,242Coins
  19. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    and I don't have a movement platform yet hehe. how can i check without the platform?
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
