  1. Einar Roland
    Einar Roland New Member
    82Coins
    I am wanting to build a 3dof Pitch + Roll + Rear Traction /yaw
    DC geared motors I can source for about 50usd plus's freight
    voltage: 24v
    output power: 150w
    no-load speed: 60rpm
    rated torque: ≥12N.m
    For more data look at enclosed pictures
    So if they good anuff.
    Then what kinda design should I go for?
    And use 3 or 4 motors and how many to upgrade to 6dof
    Really would appreciate all input on what to choose for the rest of the components.
    153,986Coins
    +11,162 / 57 / -2
  3. Einar Roland
    82Coins
    First of all thanks for the reply ! can I take your answer as these DC motors bare ok for usage?
    153,986Coins
    +11,162 / 57 / -2
    You need to check the motor specs and calculate the expected load, desired performance for a given design.
