SMC3 and quadrant encoders
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Che Franklin, Apr 21, 2020.
  1. Che Franklin
    Che Franklin im alot brighter than i look.. Gold Contributor
    Cape Cod Ma USA
    593Coins
    Hello All,
    First let me say that simtool and SMC3 is BY far the EASIEST way to get going.
    im having a Blast with the 2dof but i need MORE...
    With that said Does ANYONE have a SMC3 sketch with the following:
    https://www.digikey.com/product-detail/en/cui-devices/AMT102-V/102-1307-ND/827015
    or if someone would convert the sketch to work with them, id be willing to pay
    im redoing my rig with:
    4 Wheelchair motors
    2 Arduino UNOs
    2 Sabertooth 12/32
    I would love to use the encoders as they keep very good track of positions,
    However pots are up if we cant get encoders to work.
    https://www.digikey.com/product-det...3852C-282-103AL-ND/1088605/?itemSeq=324114198
    any1 4see any issues ???
    152,283Coins
    +11,067 / 56 / -2
  3. MarkusB
    4,215Coins
    Have a look here for a project using such encoders.
    The Arduino sketch and a test program (similar to SMC3Utils) can be found here.
  4. MarkusB
    4,215Coins
    The nice thing about the encoders - as @Bernd Manger has done it - is that the encoders are directly connected to the anchor axis of the motor instead of the gear box. In this way you don't have to mess around with pots at the gear box.
  5. Milt
    Milt Member
    USA
    32Coins
  6. Che Franklin
    Cape Cod Ma USA
    593Coins
    just took a look, thats VERY helpful THX
  7. Che Franklin
    Cape Cod Ma USA
    593Coins
    SEATIME its actually VERY simple remove Brake slide on blue 8mm sleeve to where the brake was connect encoder. I had a harder time with pots and they take more space..
  8. Che Franklin
    Cape Cod Ma USA
    593Coins
    THX YOU SOOOOO MUCH.. this is perfect.. few questions before I whip out the torch..
    Q1 is the Mega cable of running 2 Sabertooth 12/32?
    Q2 @noorbeast you had said that the need to be equal distance i have attached some pics
    Q3 will this design give me full DOF, if not what will it give me
    Q4 IF I had 2 more motors should i add them or will the 4 bee good for Drive/flight
    I'm planning on a 1/8 24x24 sheet of steel, weld motor mounts to sheet and weld in bracing for the motors, attach arms to 24x24 platform above
    I haven't decided on hight from the base thoughts?
    I'm looking for AS much (design input) and suggestions as possible.
    THX ALL
  9. Che Franklin
    Cape Cod Ma USA
    593Coins
    152,283Coins
    +11,067 / 56 / -2
    Use an Arduino per Sabertooth.
    The design, as I understand it, will be 3DOF, as it includes heave, but it could be 3DOF + sway, as per design comment and video below.
    Motor wise you need enough power to drive a given design at a desired performance level, hard to say what the motors are capable of and the design trade offs. Either experimentation or calculation will be needed.
    The base needs to be suitably braced so there is no flex.
    Design wise I would suggest a pivot frame , there are a number of ways it could be done but here is one example by @prilad:
  11. Che Franklin
    Cape Cod Ma USA
    593Coins
    thx you Noorbeast
    where can i find the build plans for that rig in the video?
    and had thought that it would have been like Dbox style on the 4 corners
    after looking at your video i saw this
    pretty similar?
    152,283Coins
    +11,067 / 56 / -2
  13. Che Franklin
    Cape Cod Ma USA
    593Coins
    @noorbeast UPDATE
    ok, its all Mocked up for welding, what do you think? I'm sooo excited the 2dof was fun but i need way more.. I hope this does the trick.
    152,283Coins
    +11,067 / 56 / -2
    How stiff is it, there should be no flex even under extreme load. I even run a cross brace between the 2 font motors of my compact rig, to add rigidity:
