SFX-100 New Build on GT1-Evo Rig
Discussion in 'DIY Motion Simulator Projects' started by dennis johnson, Mar 25, 2020.
  1. Mike5050
    Mike5050 New Member
    Chiropractor
    New Jersey
    271Coins
    Very nice job
  2. dennis johnson
    dennis johnson Member
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    Update: I received my shielded 6m cables, got some cable management done and now am tuning the rig. Thought I would post some pics. Really having fun learning simtools with a lot of help from the forum.
    I mounted the Thanos interface to the back of the rack with velcro.
    I decided to mount my buttkicker amps in the rack. Everything fit very nicely.
    Another idea that I stole from someone. I ran the actuator cables down the center of the frame and ran speaker wire down the corner holes of the extrusion. IMG_1385.jpg
    My little corner of goodness!
    Rig is currently setup for flying
    This has been a fun project! Now on to racing/flying and havin fun.......
    153,703Coins
    Exquisite craftsmanship :thumbs
  4. dennis johnson
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    Thanks. That means quite a lot , coming from you!
  5. Sim Freak
    Sim Freak Sim Freak Gold Contributor
    61Coins
    Hello! very nice build you have!
    I would like to ask if the motor and motor drive work with 110V right out of the box? Or require a transformer? TIA
  6. dennis johnson
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    Yes. Scroll up to post #15 for a link on how to do it. Very simple
  7. Waissmann
    Waissmann New Member
    17Coins
    Your build looks amazing!
    I do have a question about flex on the the GT1 Evo and the SFX-100 motion platform, I'm planning on buying a rig with the wishlist of adding in the SFX-100, which may or mayn't happen but I get mixed messages about rigidity with the GT1 evo.
    So I would love to have your first hand experience.
  8. dennis johnson
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    I am very happy with the rig overall. After using it for awhile, I can say though that I can feel a slight flex in extreme movements. Mostly in flight sims. I dont notice flex when racing though. If you have the budget, go for the PX1 if this is a concern.
  9. hasole
    hasole New Member
    Auckland, New Zealand
    60Coins
    Awesome build. I've got a gt1 evo and started looking into adding sfx to it :)
  10. hasole
    hasole New Member
    60Coins
    Any chance of having some more photos of how your hotas is mounted? and what you have to do to switch between driving and flying?
  11. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    I am always impressed how people managed to hide their cables!
    My rig is a spaghetti boal in comparison
  12. dennis johnson
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    DB584D6F-4464-4AF2-A8A2-91D609CA87CA.jpeg E1307FED-60D5-4721-B665-9F404C840C21.jpeg 7B32877F-FEBF-4B0C-A199-A7DB9C653EDC.jpeg
    It takes about 10 seconds to attach or unattach the hotas.
  13. dennis johnson
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    It takes time and planning. Plus stealing other peoples ideas. Lol
  14. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    i will setup a bluetooth multiplexer ;-)
  15. hasole
    hasole New Member
    60Coins
    Awesome, thank you very much! Quick release is the pro tip :)
  16. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    very nice build ! :thumbs
    @Thanos If i want to decrease the voltage of my drivers AASD-15A (220v-120v) , is it important of connecting drivers into 220v. before changing the data in the menu or it doesn't matter if i plug it to 120v while i change the numbers in the drivers.
  17. Thanos
    Electronics Engineer
    2,907Coins
    You can connect the servo drive to 110v and you will be able to access its parameters on its panel, even if it shows alarms for voltage or missing motor etc...
