Arduino Leonardo SIM Wheel
Discussion in 'DIY peripherals' started by Sieben, Nov 27, 2018.
  1. Sieben
    Sieben Active Member
    2,241Coins
    MarcoMade,
    it gets rather hot. Also need to make holes for ventilation. Checked after the game, don't know how much was in time, smth like for half an hour tests or a bit more, it was under 50C. The motor housing. Rotor should be smth like up till 80-90 may be. But I guess it gets some more if take a greater time. As usual, simply put. With the same power, the 540 motor get smoke, with 130c of rotor and 80c of the motor housing, with just one lap, in "dd" mode)
    With a bulb, it has less ffb ofcourse, but playble. Wanna try with 1-1/5ohms resistance on it. Checked with 25w 25ohms one, but that is too much. Had small resistors only to check the value amounts for it, came up with that numbers of 1-1/5ohms. Also to try some other power supplyes ets. But the only right way will be to make a good cooling.) The ffb force amount without current limiters is great. Especially with a smaller and lighter wheight wheel)
  2. Sieben
    2,241Coins
    Checked the torque test and a wheel under 12V12.5A Power supply appeared to be of having - 3.67 Nm of force. I made units conversion of the obtained data measured not with 1 meter lever of force, but with 7.5cm force lever. That has 5 kg at that applied point of measurement, fastened just right on that gear sprocket)
  3. Sieben
    2,241Coins
    With 12v33a - 5.5 Nm of force.
  4. tadope
    tadope New Member
    81Coins
    well I applaud your ingenuity, but I have to say that bicycle chain is the loudest thing i've ever heard!!
    I'm interested in your arduino circuitry though. I would like the know the simplest easiest way to do one of these and this looks like it. So you basically just have two arduino thingies and you set one of them up as a controller and the other as an encoder? i dont get it.
  5. Sieben
    2,241Coins
  6. Sieben
    2,241Coins
    Switched to mmos.
    Made enclosure for STM32 & Arduino. Axis are connected via usb cables.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG]
  7. Sieben
    2,241Coins
    Level of Ai 120%. Low agression.
    Powerfull FFB, motor takes 12A, with rated 14A. Good result with no super cooling of the motor to run it.
  8. celicaraptor
    celicaraptor New Member
    94Coins
    Hi Sieben,would you happen to know the wiring diagram for the VNH2SP30 and the Arduino Leonardo using EMC firmware?
  9. Sieben
    2,241Coins
  10. Daud077
    Daud077 New Member
    82Coins
    Can u tell the parts used to connect the encoder with the steering shaft.
  11. Daud077
    Daud077 New Member
    82Coins
    Can I use this Coupler to attach my 6mm encoder to 10mm steering shaft?[​IMG]
  12. Daud077
    Daud077 New Member
    82Coins
    Plz tell me Iam desperate
  13. Daud077
    Daud077 New Member
    82Coins
    Can I use a Coupler?
  14. Sieben
    2,241Coins
    For sure)
  15. Kotoshka
    Kotoshka New Member
    80Coins
    Hi Sieben, thanks for sharing your project.
    I also built mine and it is quite similar to yours in terms of motor (MY1016), a BTS, Arduino Pro Micro, EMC lite, chain reduction (mini scooter H25 1:5 approx) 12v 30a supply, hp printer encoder.
    I use LFS, Rfactor, RBR. However, I notice that there is an FFB dead zone of about 20° in both directions, that is, when reaching or passing 20° it feels like a mechanical stop, at those 40° from the center there is no effect. Does this happen to you too? or how can i fix it? Use 2PWM + 1 Dir I appreciate your support.
  16. Sieben
    2,241Coins
    Hi. Don't have that issue if smth.
    You use 2PWM + 1 Dir right? You should use H-bridge.
  17. Kotoshka
    Kotoshka New Member
    80Coins
    That's right friend. Can you share a little more information about that H-bridge? I only have the circuit connected according to the indications; from the source to BTS and from there to My1016
  18. Sieben
    2,241Coins
    Generally, you can't mess up greatly with set ups on emc lite if follow authors youtube guides. You may have faulty BTS or kinda then. Is pro micro good for it? (Despite it's kinda all the same like Leonardo) IDK.
    For mmos on stm32 on h-bridge.
    How does it look?
  19. Kotoshka
    Kotoshka New Member
    80Coins
    the micro works the same as the Leonardo except for the lack of pin 11 and other pins for the button matrix. I am using the Arduino emc lite, configured in 2PWM + 1DIR, it does not give that H-bridge option
  20. Sieben
    2,241Coins
    What is your encoder ppr? cpr in soft is scaled 4 times from that number. Is it correct with it in your set up?
