Possable Alternitive to TrippleHead2Go <$$>
Discussion in 'SimTools compatible interfaces' started by Brightonuk, Oct 4, 2009.
  1. RaceRay
    Hamburg, Germany
    23,892Coins
    MviewTech, can you set up a dead area to cut away the pixels behind the borders of the lcd screens?
  2. FAG
    FAG New Member
    Perm/Russia
    413Coins
    No, I'am wrote above the bezel gaps too is not supported.
  3. mviewtech
    mviewtech New Member
    0Coins
    I place some video at [urlguest=]http://v.ku6.com/mviewtech[/urlguest]
  4. mviewtech
    0Coins
    Hello All,
    Mviewtech release 4800x900 60hz for our MV103-HDVE PRO product. by the end of this week ,user can buy at Dhgate. If it's available in Dhgate, i will update message at here.
    input interface : one dual link DVI interface .maximum pixel clock 330Mhz
    output interface: thee DVI-I(can DVI and VGA simultaneously),maximum pixel clock 165Mhz
    accessories:eek:ne 1.5m Duallink DVI cable,one 5V/2A power supply(100-240V) AC ,one RS-232 cable
    dimension:165mmx130mmx28mm
    warranty:2 year limited warranty
    product feauture.
    1.support the world`s first 4200x1050 60Hz resolution which can support three SXGA+ projectors @ WINXP32/64,VISTA32/64 and Windows7 32/64.
    2.support the world`s first 5760x1080P 50Hz resolution @ WINXP and VISTA
    3.support the world`s first 5040x1050 60HZ resolution @ WINXP32/64,VISTA32/64 and Windows7 32/64.
    4.support the world`s first 4800x900 60HZ resolution @ WINXP32/64,VISTA32/64 and Windows7 32/64.
    5.user can enable DX10 in Vista and Windows7
    6.No HDCP
    7.No bezel management.
    8.support ATI and NVIDIA card with DVI output.
    9.user can configure display format with DDC or RS232.
    Best Regards!
    Mviewtech.
    2009.12.15
  5. mviewtech
    0Coins
  6. mviewtech
    0Coins
    Hello All,
    From now,our MV103-HDVE PRO can support bezel management. user can adjust from 1 to 128 pixels.
    Best Regards!
    Mviewtech.
  7. FAG
    FAG New Member
    Perm/Russia
    413Coins
    Great news :clap:
  8. mviewtech
    0Coins
    Hello all,
    our company update MV103 to support clone mode ,bezel management,120Hz and cascade mode.Mv103-HDVE PRO support ATI Eyefinity .MV103 have three version MV103-HDVI,MV103-HDVE,MV103-HDVE PRO
    detailed information at http://www.mviewtech.com/en/product.asp?classid=7&id=90
    Best Regards!
    Mviewtech
