Question IBT-2 Proof of Concept Before Moving On
Discussion in 'DIY Motion Simulator Projects' started by Fireblade69, Apr 2, 2020.
  1. Fireblade69
    Fireblade69 New Member
    283Coins
    Hi Guys, I've been playing with Arduino and motion control to understand the requirements for building a 6DOF rig with a friend of mine. I think I've go the hang of the programming (thank you @RufusDufus for the post in setting that up) and we've sourced motors, steel frame and cradle and we're basing the design on @SilentChill's original rig with the train wiper motors.
    My question is regarding motor controllers. The intention is to move onto Sabretooth controllers but as they are quite expensive to use as a test bed, I've got some Monster Moto Shield from Sparkfun (probably fakes) and a pair of IBT-2 Drivers. I've pretty much given up on the MM as a test bed as they don't seem to have the longevity and there are lots of posts about them being a bit flaky and burny.
    So moving on with testing using IBT-2, because they are £10 (well, x2) and not £150 so if they blow up then it's not too much £££ wasted.
    The question I have is, how easy is it to transition from IBT-2 to Sabretooth once the wiring and connections are all sorted out?
    2nd item is not so much a question as an observation as well. I've got HP 305447-001 re-purposed PSUs, one for each motor but they cut out really quickly on hard reverses or hard surges of power. I've heard there is a Diode hack to resolve that but can't find any information on it, does anyone have any ideas? I have 8 of them so if I can get them to work it would be great but they get a bit hot without active cooling so I've got a 40A/480W PSU coming that is normally used for LED lights, hopefully it will drive two motors as the motors are 16A. Not sure about that so it might be a suck it and see thing.
  2. dieser
    dieser Member
    372Coins
    as far as i know, wiring a sabertooth is way more simple than wiring a ibt2 or mm...
    so, you have to redo the wiring then, but you will need less cables...
    152,039Coins
    +11,062 / 56 / -2
    You can compare by checking out the respective setup guides:
    IBT-2 (mode 2): https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Sabertooth: https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/
    The Dimension Engineering Resistor Calculator can be found here: https://www.dimensionengineering.com/calculators/power-resistor
  4. susocalfail39
    susocalfail39 Member
    GALICIA, ESPAÑA.
    50Coins
    I have been with ibt2 for a long time and without problems and easy to connect and very cheap boards, I know people who have used them and also without problems, in a 2 dof, but in a 6 dof, is it really necessary to use the sabretooch? I ask alone.
    Use translator excuse me
    Regarding the sources, a server source used to protect me and I used 2 pc sources one for each engine, and without problems, we must also configure the smc3 well, if it is incorrectly configured the source jumps.
  5. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
  6. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Taking advantage of the topic. Do you need to use a cooler to cool the IBT_2?
  7. p00ky
    p00ky Active Member
    Wales
    392Coins
    As far as I understand it (I havent recieved mine yet). The heat sink on the IBT_2 is on the reverse side from what needs to be cooled with only via stitching to get the heat through the board, so at a guess, yes. It's probably a wise idea anyway.
  8. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    [QUOTE = "Djalma Ribeiro, post: 197640, member: 36511"] Taking advantage of the topic. Do you need to use a cooler to cool the IBT_2? [/ QUOTE]
    not
    The ibt2 if they come with a heatsink, you don't need to put anything on them, and I only have them with a fan inside an electrical box
  9. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    I also don't use diodes or anything, with 2 pc sources, one for each board and without problems, another colleague has also been like this for 2 years and also without problems
  10. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Thanks! Where is your cooler?
  11. p00ky
    p00ky Active Member
    Wales
    392Coins
    Interesting to know. I'm still waiting on all the parts but the more I hear about the ibt2's the more I like them.
  12. Fireblade69
    283Coins
  13. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    I have the fan placed in the lid of that box, but it is not seen in the photo, I made a hole with a crown, and I screwed the fan and put a grid on it.
    When I have more time I will upload another photo, with the box closed,
    those electrical registration boxes are ideal.
  14. Gadget999
    12,035Coins
