2DOF Kart Cross full frame AC Motors
Discussion in 'DIY Motion Simulator Projects' started by Eliseu, May 11, 2020.
  1. Eliseu
    Eliseu New Member
    129Coins
    I started do my 2dof simulator in 2 weeks ago, but this idea alredy have a lot years, but now is the time...
    Material that i have:
    • Logitech Driving Force GT.
    • PC (B45 pro gamer motherboard + AMD MATRIX R9290X-P-4GD5 grafic card).
    • Monitor Benq GL2460 24".
    • Creative 5.1 speakers
    Material that i bought :
    • Kart cross chassi
    • Baquet seat
    The first job was install the seat and the steering wheel:
    IMG_20200509_114654.jpg IMG_20200509_115342.jpg IMG_20200509_164149.jpg IMG_20200509_194856.jpg
    Next steps:
    • Create the definitive supports for the steering wheel and pedals.
    I will need your help...
    Thanks.
    153,986Coins
    +11,162 / 57 / -2
    Do you plan on motion just for the seat, or the whole frame, as the latter has a lot of mass?
  3. Eliseu
    Eliseu New Member
    129Coins
    My plan is on motion the whole frame...
    Yes, it was a lot of mass, but it's possible reduce a little...
    I will try use AC Motors...
    Someone have experience to help me to find the correct specifications to Motors?
  4. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    That is going to be awesome! @noorbeast is right (as usual) about the mass being a concern. But if you pivot it around the center of mass it will be a lot better. I use 1/4 horsepower DC motors on my semi-JoyRider style sim and it works fine. My frame isn't as massive as yours, but I have plenty of motor power to spare and instead was blowing motor drivers until I tuned it down a bit.
  5. Eliseu
    Eliseu New Member
    129Coins
    Nice @cgodwin, do you have a post here with details about your project?
  6. cgodwin
    Engineer
    Eugene, Oregon
    2,478Coins
  7. Eliseu
    Eliseu New Member
    129Coins
    I passed some years without play with my steering wheel, i don´t know why but the steering wheel was stuck... :confused::confused:
    Time to repair the steering wheel:
    After checked some parts, i saw that the problem was in the a lot of pressure in the gear from the motor...
    To solve the problem i widened the motor mounting holes to relieve pressure in the gears...
    Now is better... :)
    Some fotos from the steering wheel...
    IMG_20200511_183817.jpg IMG_20200511_183823.jpg IMG_20200511_183829.jpg IMG_20200511_184717.jpg IMG_20200511_185235.jpg IMG_20200511_185237.jpg IMG_20200511_185421.jpg IMG_20200511_190006.jpg IMG_20200511_213611.jpg
  8. Eliseu
    Eliseu New Member
    129Coins
    Today I reduced the weight of the chassis 10Kg:
  9. Eliseu
    Eliseu New Member
    129Coins
    Motors
    What is your opinion about these motors?
    characteristics:
    25Hz-
    50Hz-
    60Hz-
  10. Eliseu
    Eliseu New Member
    129Coins
    I need your opinion... Considering that I'm going to use a triple monitor...
    Do you think it looks better with or without coverage?
  11. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    153,986Coins
    +11,162 / 57 / -2
    Its a trade off, looks are one criteria, the other is performance, so the less mass the better for the latter.
  13. Eliseu
    Eliseu New Member
    129Coins
    Is also my opinion... :thumbs
  14. Eliseu
    Eliseu New Member
    129Coins
    It´s true, i will try made the two options, adapt the actual coverage and make a new without coverage and after i will see how it works with motion...
    The coverage have 11.6KG o_O The rest I don't know yet ...
