Force Profiler doesn´t open on Win 7
Discussion in 'New users start here - FAQ' started by Danjo1712, Nov 15, 2009.
  1. Danjo1712
    Danjo1712 New Member
    Berufskraftfahrer
    SN
    243Coins
    Hey, I have a problem. I have Win 7 and installed the X-Sim Software a few days ago. It worked fine, but yesterday i tried to launch profiler and it started. but i have no window for that. It seems to work, but i can´t see it. When I activat the thumbnail in the tray i can see just 2 of the buttons on the left in the thumbnail not more. i reinstalled it but no changes. Force sender works fine. HELP?
  2. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    I have also this problem.
    My Profiler start but the X-Sim-Windows can not open.
    I have Vista.
    All works fine but i have with Tune up my registrie defrag and now
    i cant my see the Profiler Windows.
    Actuator and GaugeDisplay load and start,in the background i see
    with taskmanager this X-Sim-task only the Profiler Windows can not open.
    Registrie Bug, new install will not help.
    Only in the taskbar i can see this little Windows from Profiler.
    And this had a defekt into presentation.
    Ver. 2.0.7.1 works fine(install this)but 2.1.0.2+3 will now not works.
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Right click on task bar --> Show Task Manager
    Then Right Click on Force Profiler and Select Maximize. You may have to do this twice .
    I think that this is some type of bug that occurs when the profiler is set top start minimized and you try to maximize it before it has finished searching for actuators.
  4. michael haertsch
    - 206Coins
    Thanks.
    The Cleaner with Admin rights start and now works fine :D
