Question 6DOF with 2 x Arduino UNOs + SMC3.ino
Discussion in 'Forum and Website' started by Sam MAHENDRA, May 13, 2020.
Tags:
  1. Sam MAHENDRA
    Sam MAHENDRA mahentheman
    Electrical Engineer
    Sydney Australia
    395Coins
    Hello my fellow XSim Community,
    I joined the Xsim community in mid 2019 and have successfully built two Motion Sims, (1) 2DOF + TC with UNO running SMC3.ino driving Wiper motor via IBT_2 and
    (2) 2DOF +TC with UNO running SMC3.ino driving 200W motors via IBT_2.
    Now I am embarking on building my third Sim; a 6DOF with 2 UNOs, each running SMC3.ino and driving 3 x IBT_2 + 3 x Wiper motors.
    Having read all the available information on the 6DOF in Xsim, I am sure that my proposed set up is quite feasible.
    Before, I start to build anything, I would like to get your feedback on the
    my proposed SimTools Axis assignments & Interface settings.
    Axis Assignments
    Interfaces
    Any feedback and suggestions, especially on ticking the correct DIR boxes for DOFs are welcome.
    153,986Coins
    +11,162 / 57 / -2
    Have you actually tested if wiper motors are powerful enough to drive a 6DOF?
  3. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Thanks for your prompt response.
    No I haven't tested whether the Wiper motor are powerful enough. I will first try them with some provision to replace them, if necessary, with the 200W motors that I used for my second 2DOF+TC.
    My concern is whether the SimTools can handle two Ards UNOs connected as Interface 1 & 2 on separate COMs?
    153,986Coins
    +11,162 / 57 / -2
    SimTools can handle the Arduinos, but I doubt wiper motors can handle a 6DOF load.
    I suspect even the 200w would need low ratio gearboxes, but someone like @SeatTime could give a more authoritative opinion.
