Question Broken part from motor to wormwheel
Discussion in 'Electronic and hardware generally' started by JonBakhol, Apr 29, 2020.
  1. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
    He guys,
    Just fired up my 2 Dof and something was rattling inside my right-motor.
    Opened it up and there was a most terrible thing I ever saw. :mad:
    It is a ZYT90-155-24-3000 with an matching worm-wheel 1:50 from https://www.motioncontrolproducts.co.uk/products/8/24/12vdc-traction-motor-zyt90-155-04-nm/
    I already wrote them an E-mail.
    But how is the piece called in English?
    And also the rubber part between the motor and the worm-wheel side?
    Or is this a common problem, and you guys have multiple part numbers, which also can be found in " The Netherlands"
    TIA
    Race on
    Bakhol
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    I have those parts spare, if you have no luck with the company I would be happy to send them on to you :thumbs
  3. JonBakhol
    443Coins
    He @Daguru
    Thanks the reply. Do you have any idea how these pieces are called? Or maybe you have a part number?
    Thanks,
    Bakhol
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    If I would to guess I would say motor coupler and bush.
    But that’s a guess.
    153,986Coins
    +11,162 / 57 / -2
    The ones Motion Dynamics sell in Australia are called Motor/Gearbox Spider Coupling Set: https://www.motiondynamics.com.au/motor-gearbox-spider-coupling-set-metal.html
  6. JonBakhol
    443Coins
    @noorbeast
    Thanks for the info. I sorted it out with the guys in England.
    Got 4 sets of these couplings for just the freight charge.
    Thanks anyhow
    Ride on
    Bakhol
  7. Gadget999
    12,174Coins
    Was it the plastic/rubber bush that had failed ?
    What spec motor and gear ratio do you use ?
  8. JonBakhol
    443Coins
  9. JonBakhol
    443Coins
    All in the additional question. (I think, or nodo I not thinking. That is the question)
    https://www.motioncontrolproducts.co.uk/products/8/167/dc-brushed-geared-motor-90zyt--mcp2---mcp4/
    Ride on
    Bakhol
    To be, or not to be, that is the question:
    Whether 'tis nobler in the mind to suffer
    The slings and arrows of outrageous fortune,
    Or to take arms against a sea of troubles
    And by opposing end them. To die—to sleep,
    No more; and by a sleep to say we end
    The heart-ache and the thousand natural shocks
    That flesh is heir to: 'tis a consummation
    Devoutly to be wish'd. To die, to sleep;
    To sleep, perchance to dream—ay, there's the rub:
    For in that sleep of death what dreams may come,
    When we have shuffled off this mortal coil,
    Must give us pause—there's the respect
    That makes calamity of so long life.
    For who would bear the whips and scorns of time,
    Th'oppressor's wrong, the proud man's contumely,
    The pangs of dispriz'd love, the law's delay,
    The insolence of office, and the spurns
    That patient merit of th'unworthy takes,
    When he himself might his quietus make
    With a bare bodkin? Who would fardels bear,
    To grunt and sweat under a weary life,
    But that the dread of something after death,
    The undiscovere'd country, from whose bourn
    No traveller returns, puzzles the will,
    And makes us rather bear those ills we have
    Than fly to others that we know not of?
    Thus conscience does make cowards of us all,
    And thus the native hue of resolution
    Is sicklied o'er with the pale cast of thought,
    And enterprises of great pitch and moment
    With this regard their currents turn awry
    And lose the name of action.
  10. yondwangmms
    yondwangmms Member
    - 148Coins
    What caused its damage? Is the load too heavy?
  11. JonBakhol
    443Coins
    Because it is cast alu. I think it is just a matter of time it will happen. Had it ones time more. But I have some spares....so ok.
  12. yondwangmms
    yondwangmms Member
    - 148Coins
    This may be the reason. The strength problems of aluminum parts cause damage over time.
