$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. Wilbo
    Wilbo New Member
    West midlands
    232Coins
    No worries pal i kinda thought that might be the case. I really need to decide now do i go down the diy aasd & 10000 ppr route or save a bit more and just bite the bullet on a simucube based system. I really like the idea of what you have done though.
  2. Thanos
    Electronics Engineer
    2,907Coins
    Ok, preparing my 90ST motor, seems it has enough torque for my needs lol.
    Can't wait for the PCB for the MMOS controller to arrive and test!!
    Thanos
    • Winner Winner x 3
  3. Gadget999
    12,132Coins
  4. Peacemaker105
    Perth, Aus
    2,022Coins
    That is how they use to make the Simucube OSW back in the day with the argon drives and MMOS then you could flash the discovery board with the simucube firmware later on and use that. I guess time will tell..
  5. Peacemaker105
    Perth, Aus
    2,022Coins
    Depends how much of a rush you are in really and your budget. I will probably one day still go simucube but if you need a wheel and want to get up and running, then for half the cost this is already proving to be a very viable solution.
  6. Gadget999
    12,132Coins
    how exactly does a 240v servo motor work
    from my understanding
    1. it converts AC to DC (some are induction motors)
    2. its basically a AC/DC motor with a built in sensor
    3. the driver is a bit like a brushless controller
    what exactly does the chip/disco board do to control the motor ? Is it telling it which direction and how much pwm to apply - like an H-Bridge ?
  7. HUANGJIN
    HUANGJIN New Member
    machinery manufacturing company
    China
    205Coins
    DC motor, Arduino, SimforceGT, Motion platform, 4DOF, 6DOF
    My test drive at rfactor 2 is perfect
    我已经用无线按钮盒拍摄了整个版本,并将在下周左右发布该视频。[/引用]
  8. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
    You are the most professional in designing PCB:):)
    We all rely on you to design now:D:p
    Thank you!:):)
  9. Milt
    Milt Member
    USA
    32Coins
    I'm very interested in this project and trying to understand the pros/cons of this approach. Obviously the cost savings is significant compared to other dd solutions, which is the biggest pro. On the cons side it seems this approach limits you to a maximum of a 10000 ppr encoder and only able to use the MMOS software. Am I missing something? Any chance this could eventually interface with the simucube software?
    I could almost convince the wife a $500 USD wheel is necessary, but no chance I'd get her to go for a $1k setup....
  10. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
    [QUOTE =“ Thanos,post:197629,member:26147”]我实际上已经准备好了一些东西...
    [ATTACH = full] 72586 [/ ATTACH]
    只需要接线DB25并订购PCB ...
    我从这里使用STM32开发板:
    https://www.waveshare.com/core407v.htm
    和程序员:
    https://www.waveshare.com/product/mcu-tools/debugger-programmer/stm32-stm8/st-link-v2-cn-stm8.htm
    谢谢
    塔诺斯[/ QUOTE]
    Hello there
    Can you share the PCB file connector you designed and share it with me?
    If you can be willing to give me a PCB file
    Send to my email: huangjin169@gmail.com
    Thank you!
  11. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
    I subscribed to your YouTube channel very early
    See you every day to release updated YouTube video 6DOF driver board
    I also like to comment and like in your video,
    Do you have an impression
    I also like to comment and like in your video,:D:D
    Do you have an impression:p:p
  12. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
  13. Thanos
    2,907Coins
    The custom pcb I designed, uses these DB9 connectors for original G27 shifter and Pedals. I happen to have these. But you can wire other type if you need to. But please give it some time to build and test a prototype first, I'll make available Gerber files, no worries.
  14. Thanos
    2,907Coins
    Hey Guys, just a quick question, does anyone can point me to 3D printed solution for shifter paddles I could add to this rim? I'll use BlueHID obviously.
    Thanos
  15. Peacemaker105
    Perth, Aus
    2,022Coins
  16. Peacemaker105
    Perth, Aus
    2,022Coins
    Nice man! Thanks for your work in making this project a reality :)
  17. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
    Ok Thanks for your reply Hard work for you We are all looking forward to your PCB file
  18. HUANGJIN
    HUANGJIN New Member
    China
    205Coins
    And when Logitech pedals and Logitech shifters were added I never thought that I need to attach other types So I just draw line DB9 Logitech interface and the line drawing is not perfect and looks bad
  19. wannabeaflyer2
    london uk
    8,350Coins
    Hi @Thanos quick question while im hitting E-bay , when the now DDFFB pcb is released i notice you moved from through hole to surface mounted devices , You mentioned you'll possibly supply the just the board and or PCB & parts as kit , or ready built would be preferred but you may not have the time to do this ready assembled option in volume , is there a pic of an older populated R&D sample so that i can see what extra items will be needed to add to my shopping list , The wave share board wont be here in time so 1st draft will be using my STM32 discovery from my other DD FFB project so i cant use the new PCB till the Waveshare version arrives
  20. Thanos
    2,907Coins
    There are not many parts on it, you may not even want to use the G27 pedal and shifter connectors if you use something else...
    Anyway see this update:
    Thanos
