value1
X-Plane V10 Plugin 2.0.2.0
SimTools game plugin for X-Plane V10
  1. pmvcda
    15,472Coins
    I did not read all the topic...
    But you get g in each direction, so just subtract the heave component in heave you get from xplane
    You keep g in the other directions, but remove it from heave
  2. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    You should be happy with 11.40 beta as telemetry in replay seems to be corrected.
    Also you will benefit from many physical improvements.
    Don’t forget to check “experimental flight model” option in preferences/general
    • Informative Informative x 3
  3. Psionic001
    Sydney
    996Coins
    Motion platform, 6DOF
    Thanks. I have been away and will download and test it today.
    Cheers
  4. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Still fighting with A. for the replay telemetry.
    It seems we have not enough resolution in the stored data for replay.
    Another fix might come ....
  5. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Good news.
    Ok, today came a 11.40b3 with increased resolution on g-loads for replay mode.
    Please test.
  6. railman pascal
    railman pascal New Member
    276Coins
    3DOF, Arduino
    Hello Value1,
    first thanks for the detailed explanation that did help me starting solving my problem of communication.
    unfortunatly, it does'nt work for me and i come to you to see if you could somehow help me.
    first what i use :
    • Xplane 10.51
    • Xsimulator
    • X plane plugin 2.0.2.0
    I did set the input/output windows as shown, so i did with the internet connection.
    the game couunicates with the simtools game engine but i have weards infos sent.
    on my screen, i have the datas i would like to send to xsilulator.
    I can read the pitch, roll and heave but on the tuning center, the datas are not the same as the one on the screen.
    when turning on the sim, it goes hard right and stays in this position no matter what i do with the plane.
    if somehow you see someting i could try....
    i also uninstalled the pluggin and reinstalled it. bu no change.
    all the best.
    railman.
  7. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Check only the UDP chceckbox “Motion platform stats” in xplane. I think @value1 uses this stream in the last plugin
  8. railman pascal
    276Coins
    3DOF, Arduino
    Hello hexpod.
    Thanks for your fast reply that did solve my problem.
    All axes are now responding fine.
    I just have to finetune them.
    Quick second question
    I have everything that respond fine when flying. The only thing i miss now is the feeling of the track before take off or when touching down.
    Did i miss anything to check in the data menu?
    Best
    Railman
  9. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    You may want to use Simtools High Pass Filter under the name « washout » in order to bring the cue to the center. Also you can tune the min/max values in the tuning center. What you are asking for is already embedded in the heave cue.
  10. railman pascal
    276Coins
    3DOF, Arduino
    Thanks hexpod
    The answer was indeed in the definition of my min/max in the tuning center of xsimulator.
    Mine were set at +60/-60!.....
    Mooving them down to +3/-3 made all the difference.
    Thanks very much for your help and support.
    Best
    Railman
