How to Make Dirt Rally 2 Work |
Discussion in 'Dirt Series' started by Ipponen, May 21, 2020.
  1. Ipponen
    Ipponen New Member
    - 107Coins
    Tell us how dirt Rally 2 makes it work. Step by step how to install dirt2. I've tried to install some time, but I do not understand what should the make / put were going. I have received a game engine and game manager to work in blue when DiRT2 on top of a batch, apparently correctly, I wish you would not even have them installed then oikein.En not a computer geek who understands what you should do.
    154,570Coins
    +11,190 / 57 / -2
  3. Ipponen
    Ipponen New Member
    - 107Coins
    I have a Prosimu T1000 3M. I have a 64 bit application. Yes I can find that path in C: \ Users \ Your_User_Name \ Documents \ My Games \ DiRT2 and when I connect Game Engine / Game Manager, Game Manager will show blue during the game but no movement.
  4. Ipponen
    Ipponen New Member
    - 107Coins
    Assetto Corsa / ETS "/ XPlane works fine for me.
  5. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Pictures of your setting might help include Tuning centre picture as well:thumbs
  6. Ipponen
    Ipponen New Member
    - 107Coins
    154,570Coins
    +11,190 / 57 / -2
    Please post a picture of your axis assignments and a picture of the Tuning Center while DR2 is running.
  8. Ipponen
    Ipponen New Member
    - 107Coins
    154,570Coins
    +11,190 / 57 / -2
    No data is getting through to the TC.
    Try temporarily disabling your firewall and anti-virus, to check if either are messing with communications.
  10. Ipponen
    Ipponen New Member
    - 107Coins
    I played didn't work. When I turned off Capture Min Max while the game was on, the dirt went on pause, meaning some band apparently is.
    154,570Coins
    +11,190 / 57 / -2
    Try running the game windowed, instead of full screen.
  12. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Check in your
    hardware_settings_config.xml or
    hardware_settings_config_vr.xml if you are using VR,
    found below
    C:\Users\*your username*\Documents\My Games\DiRT Rally 2.0\hardwaresettings
    and make sure that it has this line in there
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
    example
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" extradata="1" ip="127.0.0.1" port="20777" delay="1" />
  13. Ipponen
    Ipponen New Member
    - 107Coins
    Such were found, whether something needed to be done and how it should be done, if necessary.
    Note. I am not a computer expert.
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Ipponen
    Replace the line that starts with <custom_udp enabled with the one below
    do it in the VR one as well if you use VR,
    you will need to edit it with notepad or even better notepad++
    let me know if this works :thumbs
  15. Ipponen
    Ipponen New Member
    - 107Coins
    I put the xml file, hopefully right. I tried it didn't work. I ran the race, did not work. I tried to remove the patch but couldn't get it removed manually. I put the patch again, I ran the race, it didn't work.
    Starts going finger to mouth what does that make you work. Are these so hard to get to work.
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    sorry i just noticed it looks like this line above the one you changed needs changing to this
    if you can send me the 2 files i will test on my rig make changes and send back :thumbs
  17. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    try these back yours up first then copy them in
    im sure this is your problem as i had the same problem its like the patch failed so i had to do it manualy.
  18. Ipponen
    Ipponen New Member
    - 107Coins
    When I put in the new patch, then I can't get in touch between the game engine and the game manager. Previously there was a connection. I put the hardware you sent, but did not connect. There will only be an attachment.
  19. Blackflam
    Blackflam New Member
    - 19Coins
    Thanks for all this information hug:
