$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. Thanos
    Electronics Engineer
    2,854Coins
  2. Thanos
    2,854Coins
    Here is a proper racing test. Lots of crashes to evaluate the max torque situations:
  3. Sieben
    Sieben Active Member
    2,241Coins
    Thanos, hi! Can you share the step test file please?
  4. Thanos
    2,854Coins
    How do you save it in a file?
  5. Chris Indeherberge
    Chris Indeherberge Designer / dreamer
    Graphics Designer
    Belgium
    184Coins
    Watching this topic closely. Nice to see other ways to use these motors and drivers in a much cheaper way then with a granity driver.
    @Thanos will these boards be for sale in the future? Pre-assembled or in diy maybe?
  6. Sieben
    2,241Coins
    Thanos, it is located in the windows documents folder, after the tests.
  7. Thanos
    2,854Coins
    Maybe, exploring ways to produce some boards without cost too much and without taking much of my time that I need to develop on the actuator servo systems.
    Its not my development anyway and have no access to the source of MMOS firmware to improve it further.
    Also I hear complaints about the AASD servos have 2500 CPR encoders (10000 positions per revolution) and that is not enough. But that is up to AASD manufacturers to provide higher resolution encoders if that is possible.
    To me seems detailed enough, but you know, always someone will try to compare it with $1000 steering wheels...
    Thanos
  8. Thanos
    2,854Coins
    took a video while testing...
    Ok, here are the logs:
  9. wannabeaflyer2
    london uk
    8,339Coins
    Remember Guys this Project "is what it is" , Seen by some as a potentially decent entry level DD FFB wheel setup , not/never meant to perform on same level as Bodnar , Simcube OSW etc but that it's another diy branch, but based on the idea that we can benifit from what its performance allows as is, and that with increased user feedback the options for refinement and improvement usually comes along with the journey, this much i have learnt through this community :)
    if theres a way to improve it i then members will find it, point to it , and chime in with ideas we always do so Win Win either way . these are exciting times ,developments fast and furiious progress keep coming now all we gotta hope is that Lockdown comes to end soon LOL and we can crack on
    • Agree Agree x 4
  10. Sieben
    2,241Coins
    The graphs data:
    And if you want to compare to OSW-Small-Mi-GE-Direct-Drive-Wheel from here
    The logs:
    https://www.dropbox.com/sh/n5mpw0qw6km2wg8/AAA9sqJHvl_Bg1rrqPTsKDsea
    Thanos, one of the suggestions just to try, to use a bit lighter wheel, but that's cool with this too. And give a try with EMC on arduino. It's kinda powerful then MMOS.
  11. Thanos
    2,854Coins
    Yeah, my rim is a bit heavy...
  12. Sieben
    2,241Coins
    2 kg? If yes, Yeah, a heavy one.
  13. Thanos
    2,854Coins
    2lbs and 10 ounce, or 1kg and 195grams...
    Feels heavy and solid...
    How much is the weight of that mige rim?
  14. Sieben
    2,241Coins
    1.2 kg is alright. I don't know. Generally recommended to hold it lightweight.
  15. sedesa tatasa
    sedesa tatasa Member
    509Coins
    The speed limit seems too low for LUT generator.
    OSW is about 200 rpm.
    Squeaks are normal sounds of industrial ac servo speed limits.
    You can see it by setting it extremely low.
  16. wannabeaflyer2
    london uk
    8,339Coins
    General Question , will the above wheel check test show more or less favourable results if using the 130ST-M10015 (15NM) motor instead of the 90ST version using the controller and standard encoder ?
  17. karldink
    karldink New Member
    75Coins
    @Thanos where did you buy your 90ST motor and driver? And how much did you pay?
    Weighing up the options between a 130ST and a 90ST as shipping to South Africa for the 130ST is US$200+. Shipping for the 90ST is significantly cheaper.
  18. Peacemaker105
    Perth, Aus
    2,014Coins
    hey mate i'll do a step test on mine now if you want. :) Any other settings i need to change?
  19. Sieben
    2,241Coins
    Hello) always interesting in this of course.:) No settings generally on default. Just as is will be fine.
  20. Peacemaker105
    Perth, Aus
    2,014Coins
    @Sieben Here's one at 100% force @ 600ms and 300ms... What is this testing? the wheel speed?
    edit: added 300ms one like the video above
    Please interpret this information for us and what it means haha
