Controlling a 220V Fan with Game Dash
Discussion in 'SimTools compatible interfaces' started by MarkusB, May 30, 2020.
  1. MarkusB
    4,215Coins
    I would like to present you my little weekend project, which I had in my mind for quite some time and which I implemented during the last two days.
    As many other members, I am using @SilentChill 's famous setup for simulating air stream.
    Since the Seaflo fans are quite noisy, I wanted to try a setup with a rather quiet 220V desk fan. At a later point in time, I may replace my current fan with a really strong wind machine.
    Since I do not want to mess around with high voltages, I decoupled the 220V circuit completely from the Arduino side. The way of my choice is a ready-to-use speed controller for 220V fans with a potentiometer, which I connect to an RC servo.
    Here is a picture of the speed controller box that I got from ebay. It is capable of handling 900W, which should be more than enough also for really big fans.
    I replaced the turning knob with a cog, put a second cog onto an RC servo, and mounted the servo to the outside of the speed controller box. Here is how this looks like.
    In addition to the servo, I use a relais for powering the speed controller only when the Game Dash speed value exceeds a certain minimum limit. The reason is that very small speed values result in a humming noise of the fan.
    Here is the simple wiring diagram:
    These are the Game Dash settings for No Limits 2:
    And here is a first video of a rollercoaster ride:
    I have also attached the Arduino code. Credits go to @SilentChill, from whom I borrowed the ReadData() function that provides the connection to Game Dash. In fact I took his entire wind simulation code and replaced the MonsterMoto part with a simple servo code.
    If you want to try this setup, you may need to adapt the constants for the servo range in order to align the servo rotation range to the rotation range of the potentiometer.
    Best regards,
    Markus
    • Creative Creative x 3
    153,986Coins
    +11,162 / 57 / -2
  3. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Hello Marcus!.. I have incorporated your sketch with a model aircraft electric ducted fan. The fan is 90mm in diameter and is running through a 10 meter 100 mm vent hose.. It is drawing 62 amps @ 24volts dc. About 1500watts of power... Velocity is about 120 kph.. I like this fan as it has a pretty fast spool up time... The output of the Arduino goes right into the electronic speed control. I most likely will play with the pwm values to see if taming this beast is needed..
  4. MarkusB
    4,215Coins
    Wow, that looks like a strong little beast.
    A week ago I bought a rather big one:
    It has a diameter of 50 cm and a rated throughput of 6.562 m³/h. It runs with 220 V and has 120 W.
    Before this, I was using two 12V Seaflo blowers.
    The Seaflo is really powerful, probably similar to yours. When you position your nose 5 cm in front of it, it literally takes your breath away.
    My current big one does not have this effect, but I like the wide field of wind that you get with it. And with a distance of about 1 m it still produces a considerable storm.
