3d printed potentiometer Cog.
Discussion in '3D Printing' started by lindo123, May 30, 2020.
  1. lindo123
    lindo123 Gamingfeeling
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    I've recently noticed this cool design that would save a lot of time and give position feedback quite efficiently. Does anyone know of any STL or .OBJ files like this?
    153,986Coins
    +11,162 / 57 / -2
  3. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    I designed this gear in tinker cad. It's designed to fit a 12 volt wiper motor but my require drilling.
    The attached file is a txt file extension but if you change by renaming it to a .stl it should open as that.
    • cog.txt
      142.7 KB
      576
      59.1 KB
      1,647
  4. Mechromancer
    434Coins
    This is interesting, but is the material used going to be "sturdy" enough to handle the constant use?
  5. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Hi, in the end I never used cogs I used a 3d printed bracket to go on the back hold the potentiometer and it has a hole to spin with it. It works perfectly fine and will also avoid destroying the poentiometer as it's glued and will easily fall off under to much pressure Here is a picture. IMG_20200704_185508.jpg
  6. Mechromancer
    434Coins
    Ah. Did you try it already? Have you played "normal" game sessions? If so, how does it hold up?
  7. lindo123
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    I haven't played in normal game sessions but the times I have tested it it has held up very well. I would recommend doing this and I just don't see this breaking as the mount dosen't go through any stress at all unless you sit on it without the motors running. I haven't used this in my project yet as I am working on a project very similar to this one: https://www.xsimulator.net/community/threads/prototype-6dof.5045/. I will be posting my project myself once completed so I will notify you if you want to see if they worked. :)
  8. Mechromancer
    434Coins
    Yeah, definitely let me know. I really want to see how it turns out.
    Good luck.
