INA122 for Thrustmaster TX
Discussion in 'DIY peripherals' started by GiantMarcin, May 4, 2020.
  1. GiantMarcin
    GiantMarcin New Member
    62Coins
    I would like to connect:
    1. 20 kg load cell (throttle),
    2. 20 kg load cell (cluctch),
    3. 100 kg load cell (brake).
    to THRUSTMASTER TX WHEEL BASE.
    I want to use INA122 or INA125 but im not an engeneer and i need help :)
    Could anyone tell me how can i connect INA125 with load cell?
    I've found this article:
    https://www.instructables.com/id/Ra...W1KXBa58pE9sqQeu_PZuJxel1c-EOzH2SPVNrXJxF5qfk
    Can you tell me what exactly i have to buy?
  2. Niranjan
    Niranjan New Member
    75Coins
    I would suggest using an HX711 instead of INA122A.It has higher resolution and is easier to implement .If you want i can share you the code.
  3. Chris_Beeves
    2,184Coins
    Maybe I missed something, but why do you want load cells on throttle and clutch?
    Regarding the INA, it is quite straightforward. You need a 1k multi turn potentiometer per load cell, other than that just some wiring (and maybe a breadboard). That will give you 0-5V (about) with 0-100% brake on the output. If the TX accepts that signal, all is good. (the logitechs have inverted signals.. )
  4. Erik Middeldorp
    Erik Middeldorp Member
    sheet metal worker
    Auckland, New Zealand
    654Coins
    have you read this thread: https://www.xsimulator.net/community/threads/diy-load-cell-brake-pedal-short-tuto.6042/
    If you use the HX711 you'll have to hook it up to an arduino. If you use the INA122PA you should be able to replace the existing potentiometers in your pedals.
    I'd suggest you get:
    https://www.aliexpress.com/item/32960268881.html
    https://www.aliexpress.com/item/32615459762.html
    https://www.aliexpress.com/item/610826601.html
    https://www.aliexpress.com/item/32844777226.html (the 1kOhm version)
    https://www.aliexpress.com/item/32707169900.html these are the spade terminals I got for my G27 pedals, I don't know if the same ones would fit thrustmaster pedals.
    The strip board circuit in the attached zip is for the G27 pedals which iirc the output is high at rest and decreases when you push the pedal. If you want to reverse that, you'd have to connect the REF pin (pin 5) on the INA122PA to ground instead of +ve and swap the load cell +ve and -ve outputs. In the drawing, the red bits are wire links between the strips, the light blue (or whatever color that is, I'm partially colorblind) circular bits are where the strips are cut.
    I haven't heard of anyone using a load cell for the accelerator or clutch, I'm not sure there would be any advantage over a trim pot.
  5. Chris_Beeves
    2,184Coins
    @GiantMarcin, listen to this guy ^^
    Excellent post, very informative and helpful!
  6. DinhoBR
    DinhoBR New Member
    Engineer
    Brazil - Rio de Janeiro
    170Coins
    [QUOTE = "Erik Middeldorp, post: 199542, membro: 31067"] você leu este tópico: https://www.xsimulator.net/community/threads/diy-load-cell-brake-pedal-short-tuto. 6042 /
    Hello Friend. I made a PCB using the INA122 for my Thrustmaster T3pa Pro pedal. He had seen the project in a video in which another friend made for pedal G27. I asked if it would work with the pedal of my T500RS and the answer was positive. It really worked, but I have small "swings". I think some filter is needed. I found on the net an example of a board that uses 2 more 10nF capacitors, attached photo, but I don't know how they would be inserted in the circuit. Would you know? Sorry my english .. I'm from Brazil. Hugs
      151.8 KB
      2,911
  7. Erik Middeldorp
    sheet metal worker
    654Coins
    Sorry, I don't know.
  8. Hannu
    Hannu New Member
    105Coins
    Hi Erik, thanks a lot for so great contribution!! hug:
    I am managing to convert my crappy 2 pedal set (from the Thrustmaster T150) to load cell ones, and if I understood well, the PCB I must create based on the one for G27 you put, should be like this. I swapped load cell ve outputs and linked pin5 of the INA122 PA to ground. Could you please confirm it?
    Thanks a lot!
  9. Erik Middeldorp
    sheet metal worker
    654Coins
    Yes, that looks correct.
  10. Hannu
    Hannu New Member
    105Coins
    Ok, thanks for your quick response. Will proceed with it, and will feed back with the result. :cheers
  11. Hannu
    Hannu New Member
    105Coins
    Hi guys, this goes slow but safe :)
    I assume both the pot and the cap have not polarity, is that ok?
  12. Hannu
    Hannu New Member
    105Coins
    Detail view of the load cell placement. I did a 3d support for it.
  13. Hannu
    Hannu New Member
    105Coins
    ... and it works! :cheers
    thanks all who contributed here
  14. RacingMat
    21,088Coins
    congrats!
    glad if my tutorial helped you!
  15. Hannu
    Hannu New Member
    105Coins
  16. Alecont
    Alecont New Member
    139Coins
    Hello, one question, I printed the pcb of this link: https://www.instructables.com/Racing-Sim-brake-pedal-load-cell-interface/ Could you help me to know which components I should use ?? The post says: capacitor 0.22uf 50v and resistor 400r, but the author told me that for my load cell of 4 cables 100kg I must use a multi turn potentiometer of 1k, but how do I implement it in that PCB ??
    I'm from Argentina and it's expensive here. So I want to be sure when buying the components and spending only once.
    Thank you, I'm sorry for the inconvenience and my bad English.
    Atte: Alexis.
  17. Alecont
    Alecont New Member
    139Coins
    Hello, I printed the pcb from this link: https://www.instructables.com/Racing-Sim-brake-pedal-load-cell-interface/ But the author told me to consider replacing the 400r resistor with a 1k multi turn potentiometer for my 4-wire 100kg load cell. But it has 3 pins, where I adapt it on that PCB ?? I already made it print, and here in Argentina it is expensive, so I want to make sure about which components to buy to spend only once. I want to use it in arduino leonardo and later in stm32.
    Sorry for the inconvenience and my bad English.
    Atte: Alexis.
  18. Erik Middeldorp
    sheet metal worker
    654Coins
    You use the middle pin and one of the end pins. Read this: https://www.electronicshub.org/how-potentiometer-works/
  19. Alecont
    Alecont New Member
    139Coins
  20. Itamar
    Itamar New Member
    - 4Coins
    ca
    can you measure the amplifier output voltage? I´ve made this circuit but it only output 2.4V.
