Question SaberTooth 2x32 SCM3 Arduino - output testing doesn't move the motor
Discussion in 'SimTools DIY Version' started by MichaelS, Jun 2, 2020.
  1. MichaelS
    MichaelS New Member
    135Coins
    After a while away from here when we doing some rebuilding in the workshop i picked the build up a few days ago but struggling to make the motor move in output testing in simtools engine.
    (in photos is shows simtools demo because i have a new laptop and haven't patched the diy version i have bought yet).
    While simtools testing i did close the scm software before starting up simtools. My settings are posted below.
    I followed the tutorial from blazinH : https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/
    and when the motor is powered on it does move correctly to the zero point so to say.
    If anybody has any idea what im doing wrong or what mistakes i have made i am happy to hear.
    Thanks in advance.
    Michael
    2020-06-02 22_13_49-Question - SMC3 + Sabertooth 2x32 + ZYT90-155-12 MCP4.png 2020-06-02 22_16_00-Question - SMC3 + Sabertooth 2x32 + ZYT90-155-12 MCP4.png 2020-06-02 22_16_47-Game Engine.png
    153,884Coins
    +11,154 / 57 / -2
    Can I please clarify if SMC3 responds as expected, as that has to be properly configured and working before messing with SimTools, also what motor shields are you using?
  3. MichaelS
    MichaelS New Member
    135Coins
    I just found out i was using the output on motor 2 from the sabertooth, in simtools i sway and surge to axis2a and it worked.
    easy fix luckily but maybe a bit dumb :roll
    Just have to figure out the jittering now when using the square structure in scm3.
    If you got some pointers that would be nice. Tried a few things in the pid settings but not a lot of luck so far.
    If i up the pwm max to a bout a 100 it jitters that hard that it goes mental and i have to shut it down because it just keeps on rotating full circles on way.
    here a quick movie of the jitter.
    153,884Coins
    +11,154 / 57 / -2
  5. MichaelS
    MichaelS New Member
    135Coins
    Been reading that pdf file and watched some of the video's. But i can't get rid of the overshoot unless i lower the proportional dramaticly or the pwm max. If i add integral only by 1 it starts to jitter even more. When adding derative even up to a 1000 it still overshoots.
    Having such a low proportial just doesnt feel good. In your previous post you mentioned try 235. I tried that and it just went nuts with pwm max at over an 100.
    2020-06-03 17_34_50-PID Without a PhD.png 2020-06-03 17_37_43-Windows SMC3 Setup and Monitor Utility.png
