Bug simtool not working
Discussion in 'SimTools Pro & Entertainment Version' started by nega alnega, Jun 4, 2020.
  1. nega alnega
    nega alnega New Member Gold Contributor
    56Coins
    4DOF
    hey,
    i have really annoying problem and i tried so many thing to get it to work but no luck .
    first of all i don't know where i should write my problem but here i think i can get help
    my problem is that when i connect to sim tool and go to test output and press turn on nothing happen
    also when i connect it to iracing nothing happen
    i'm using AMC interface AASD15A , also using windows 10
    i have tried so many things
    i have tried 2 different PC ,and both pc on english language
    i have tried using 2 different professional license
    also tried uninstalling sim tool and reinstall it
    also tried installing simtool while windows defender is turned off
    also tried installing sim tool on fresh windows version
    updating windows to the latest version
    also tried deleting the FTDI driver provider and plug the usb again
    also i don't live in US i don't know if that matter but maybe the IP matter , also tried using VPN didn't work
    i tried patching iraicng .
    i contact the support many times but no one responded to me
    note that i have tried using flypt mover and it work just fine but no luck with simtool
    i have spent more than 200$ for this sim app hopping it will work but no luck
    153,986Coins
    +11,162 / 57 / -2
  3. nega alnega
    56Coins
    4DOF
    i have used different setting not only this
    153,986Coins
    +11,162 / 57 / -2
    In all of the images Game Manager is Off (top left), which means Game Engine is disconnected from the game.
    Does Output Testing work as expected on the Default Axis Assignment profile?
    @Thanos do you ave advice re AMC settings?
  5. nega alnega
    56Coins
    4DOF
    yeah it's off but when i open iraicng it connect automatically and it says game on , i turn it off to take the photos
    output testing doesn't do anything when i try it
    yes i have thanos controller and i talked to thanos about the controller but it seems it work just fine
    153,986Coins
    +11,162 / 57 / -2
    If Output Testing does not work something is interfering with communications, if @Thanos and yourself both believe the board is working and is configured correctly. Try temporarily disconnecting the firewall and anti-virus to see if either of them is the culprit.
  7. nega alnega
    56Coins
    4DOF
    i tried installing the simtoll when the anti-virus is off on both PC didn’t work , didn’t do anything with firewall i think turning the anti-virus is enough
  8. nega alnega
    56Coins
    4DOF
    i checked firewall was off , it was off when i was install the simtool
  9. yobuddy
    51,560Coins
    Please try output testing again, but select the "( a ) Axis Assignments" to control from the drop down list in output testing.
    Do you get any movement?
    Take care,
  10. nega alnega
    56Coins
    4DOF
    yaeh i tried this before no movement
  11. yobuddy
    51,560Coins
    I know others are using this interface, are you using v2.4 of SimTools and the latest firmware for the AMC-AASD15A?
    @Thanos Any ideas buddy?
  12. Thanos
    Electronics Engineer
    2,908Coins
    Come to my Discord, there are various things to check and its easier on that real time chat...
    https://discord.gg/bx4PxYR
    Thanos
  13. nega alnega
    56Coins
    4DOF
    yeah after all this time it didn't work yet .. i'm playing with flaypt , waiting for sim tool v3 it might fixx my problem
    so i have a question the Engine IP in the game mangegr tools does it have effect?
    maybe it's the problem after all since i have tried 2 different pces
  14. yobuddy
    51,560Coins
    For a SimTools installation on a single PC the IP address should be 127.0.0.1 for both Game Manger and Game Engine.
    Hope that helps,
  15. nega alnega
    56Coins
    4DOF
    yeah i thought so
    but guess what @noorbeast , someone just helped me fix this problem
    in my case ,, u need to go to windows setting and then to time & language
    under related settings open Administrative language settings
    change all the language to English I'm not sure if it work with only US but that what I chose and Simtool finally working
    it only took me 7 months to fix this stupid problem
    actually I remember someone I think in discord mention that I need to change the input language but I didn't know about Administrative language setting I thought input language what was matter , also I searched online didn't see anyone mention it
    but heeh it's finally working
